Anonymous | i did what you said and when i save it my reciever just goes off without saving |
eral Unregistered guest | downloaded new bin file but it is not complite can"t put it in my FTA Ultra re. help plese. |
Anonymous | evertime i try to store it the reciever just turn off |
Mr. Bean Unregistered guest | Update How to change the NAGRA2 Key codes (for Fortec Lifetime Ultra only) 1- Press Menu button on your remote control 2- Press right arrow key 2 times Channel Edit 3- Press down arrow key button 2 times, press OK (Code) enter 1010 4- Press the down arrow key to Set Default Key, click OK 5- Press the up arrow key to Nagravision click OK 6- On your top left you should see Nagravision-1...if not, then you've got the wrong BIN version. 7- Press right arrow key until you see Dish Network on top 8- Press the down arrow key once to Key Number 9- Press right arrow key 2 times the from Key Number 00 - 01 - 00 ( Now take notice that on your top left you should see Nagravision-2 now ) 10- Then press DOWN button key to change the keys manually on Key Number 00 11- Enter new Keycode, do the same procedure to enter the the keys on Key Number 01 Note: Satellite Providers changes the stream key codes unpredictably, (Note: remote control key letters equivalent) A = Sat, B = i, C = Tv/Radio, D = Pause, E = Audio (speaker), F = EPG 12- Check and make sure that you got all the keys....Press OK to store (save) 13- Press EXIT key 3 times to exit to the channels. Note: If you accidentally lock the KEYCODE (OFF) use this default password 1668 ************************************************* DishNetwork Current Keys (Changed December 06, 2005)...still Active as of Dec 20,05 KEY 0 = 3D 73 19 22 27 5D C2 C9 KEY 1 = 97 96 5A 0C A5 79 27 F9 DishNetwork Current Keys (Old codes) KEY 0 = AF 0C BD 48 D8 51 6D DC KEY 1 = FE 44 D6 0C A3 6E 59 42 |
Mr. Bean Unregistered guest | update use Al7bar FTA Ultra_112005_284t3_12H_clock_api(NTSC) How to change the NAGRA2 Key codes (for Fortec Lifetime Ultra only) 1- Press Menu button on your remote control 2- Press right arrow key 2 times Channel Edit 3- Press down arrow key button 2 times, press OK (Code) enter 1010 4- Press the down arrow key to Set Default Key, click OK 5- Press the up arrow key to Nagravision click OK 6- On your top left you should see Nagravision-1...if not, then you've got the wrong BIN version. 7- Press right arrow key until you see Dish Network on top 8- Press the down arrow key once to Key Number 9- Press right arrow key 2 times the from Key Number 00 - 01 - 00 ( Now take notice that on your top left you should see Nagravision-2 now ) 10- Then press DOWN button key to change the keys manually on Key Number 00 11- Enter new Keycode, do the same procedure to enter the the keys on Key Number 01 Note: Satellite Providers changes the stream key codes unpredictably, (Note: remote control key letters equivalent) A = Sat, B = i, C = Tv/Radio, D = Pause, E = Audio (speaker), F = EPG 12- Check and make sure that you got all the keys....Press OK to store (save) 13- Press EXIT key 3 times to exit to the channels. Note: If you accidentally lock the KEYCODE (OFF) use this default password 1668 ************************************************* DishNetwork Current Keys (Changed December 06, 2005)...still Active as of Dec 20,05 KEY 0 = 3D 73 19 22 27 5D C2 C9 KEY 1 = 97 96 5A 0C A5 79 27 F9 DishNetwork Current Keys (Old codes) KEY 0 = AF 0C BD 48 D8 51 6D DC KEY 1 = FE 44 D6 0C A3 6E 59 42 |
Anonymous | Can somebody please tell me how can I download a channel list into my receiver. It is a ndf file. I have a 2500Pansat.Thanks a lot. |
Bronze Member Username: Rzoo4u2cPost Number: 23 Registered: Oct-05 | these are the current code you have them flipped over 2 posts up DishNetwork Current Keys as of 12-20-05 KEY 0 = AF 0C BD 48 D8 51 6D DC- KEY 1 = FE 44 D6 0C A3 6E 59 42 - |
Anonymous | does the new keys give you a lot of ppv, adult, local, etc...how many channel can i get out of the new key? |
Gold Member Username: Thill1951akalkPost Number: 1135 Registered: Oct-05 | ALL the newest keys are posted in the "NEW KEYS" thread..the keys are the same for every receiver...they do not change by receiver type..they work on all Pansats, Fortecs, Co*olsat, Viewsat,Digiwave, clones etc...its even posted there how to input them...and if U were smart U would upload an autoroll bin and not need to manually input the keys! |
Anonymous | where can i get this autoroll bin...what other satelite provider can i used be side dish network and get batter channel... |
Gold Member Username: Thill1951akalkPost Number: 1141 Registered: Oct-05 | Every file and all the info U'll ever need is in here...just pick any one of the links! https://www.ecoustics.com/electronics/forum/home-video/183727.html |
Anonymous | hay my fortec has a problem...everytime i downloaded the file to my fortec lifetime ultra, it got 100% but on my computer screen it shows file failed, and when i turn it on the lang...part comes on and i put english...move to the new screen to set my reciever mode and etc...then i when right one time to the scan screen, i pick 119 and after i pick that i went down to scan and press ok...the save box popup and it try to save then my fortec just shut off with out saving...i try again this time i try to reset the defult key and it try to save but shut off as well...any one have any idea what is wrong or wat is missing...thanx |
Anonymous | i downloaded updater for this site www,exterme micro ind. and his one from the 12/07/05 worked but not the 12/21/05 and can't get the one that you put keys manuley don't kwon what to do next help thanks. |
DMD Unregistered guest | Hello, i just got pansat 2700E. i have dish 500, 119W,zipcode is 28269, i have no idea how to put key in this receiver. can any help me put the key. and aslo help me find direction of 148W and 121W.ZIP CODE 28269 |
Gold Member Username: Thill1951akalkPost Number: 1154 Registered: Oct-05 | For All Pansats -------------------------------------------------------------------------------- Press menu button on your remote: #1 Go to parental control... #2 Go down to "second pin" option & enter 0000 #3 Then go to nagravision and select it by pressing ok button on your remote... #4 In Nagravision window you should be in the box that is Entitled "Provider ID"...scroll to the right (press right arrow button on remote) until it switches to Dishnetwork (00 01) #5 Now In Nagravision window go down (press down arrow on remote) to the box that contains "00" entitled "Key Number" #6 While in the box (highlighted "Key Number") that contains "00", scroll to the right until you see nagravision 2 at the top left of your screen #7 While in Nagravision2 you should still be in "Key Number" box and the number in that same box should be "00"...this is for Key 00 #8 Scroll down (press down arrow on remote) to key data and enter the new supplied key for 00 (within this site is the key change for Nagravision2)..take note on how to enter letters in the lower portion of the screen (ex. letter E=FAV button on remote) #9 Once key is edited select OK button on your remote (OK-STORE confirmation blinks twice in lower right of screen) #10 go back to the "00" box and move one click to the right which should take you to "01"..this is to edit the "01" key #11 Follow Steps 8 & 9 above (this time enter key data for key 01 instead of 00) #12 Click exit and click ok or yes to save changes then exit all the way out and you should be watching tv Note...For /Bell keys at step #4, "Provider ID" is 09 - 01 Satellite Finders (Look Angle Calculators) ------------------------------------------------- [link removed] |
DMD Unregistered guest | hey thanks man, i need key for Nagravision-2-DISHNETWORK,Provider ID 00-01, Key number 00. So please is there any one who can give me Key DATA. |
DMD Unregistered guest | oh i also put DishNetwork Current Keys (Changed December 06, 2005)...still Active as of Dec 20,05 KEY 0 = 3D 73 19 22 27 5D C2 C9 KEY 1 = 97 96 5A 0C A5 79 27 F9 nothing happend, all channels are still $$$$lock$$$$. can any give me correct key |
Gold Member Username: Thill1951akalkPost Number: 1155 Registered: Oct-05 | DMD...c'mon dude...those are the INACTIVE keys..READ the thread "NEW KEYS"..and get the right keys...cannot spoon feed U anymore..do SOMETHING ON YOUR OWN! |
DMD Unregistered guest | ahahahaahahaha, hey really i figure it out, thanks again, this is first time i done something like this.and it does work. bye, Take Care |
Anonymous | Hello there, A newbee needs help from the nice people here. I just got pansat 3500s and am trying to load the bin file using the null modem cable that I got with the reciever, but the download stops at max 11 % and then the reciever reboots and then the loader just hangs. I have tried many times but without success. Any help will be highly appreciated. |
Lija Unregistered guest | Hello Thill or anyone with experience, A newbee needs help from the nice people here. I just got pansat 3500s and am trying to load the bin file using the null modem cable that I got with the reciever, but the download stops at max 11 % and then the reciever reboots and then the loader just hangs. I have tried many times but without success. Any help will be highly appreciated. |
Bronze Member Username: EccomanNorth bay, Ontario Canada Post Number: 11 Registered: Jun-05 | I hope someone can help me I am a newbie so bear with me. I have a multistar with fortec on it. Originally it had panset programming on it but I took into a friend who put fortec programming on it. Will this affect the receiver when I try to download bin files or do I have to reload panset program. If I do have to reload panset can someone tell me how to do it. Thanks in advance and happy holidays |
Aktek03 Unregistered guest | hey there....in need of a little help i have a fortec and have followed all the steps above but once i reach the "key Number" screen and press to the right 2 times or one hundred the top left does not change to nagravision2....please help... |
Unregistered guest | HI, I have fortecstar lifetime ultra receiver and YES I have uploaded the newest BIN files and new KEYS for Nagravision 2 and channels are working but I still cannot see NAGRAVISION 2 on my top left corner when I move from key 00-01-00, it does not change anything... Do I need to download any other BINS... Thanks in advance |
Bronze Member Username: TruckerPost Number: 15 Registered: Oct-05 | "plavi01" you didn't say witch bin you have. sounds like you have the fortec 282t bin with updated keys in it. theres no n2 key option in this bin. your bin will work fine until the keys roll. i think the fortec 284t bin does have the n2 key option. i'm running a moded pansat 267t bin autoroll on june 2004 fortec with good chip set. and pantec 257pv4c bin on fortec nov 2004 with bad chip set. both bins have n2 option, hoped this helped. |
Unregistered guest | Thanks 808 Yes I have 282t bin and I have been reading about this 284t bin and it seems to be killing receivers some kind of a time bomb or whatever so if there is a safe file that I should update let me know... Thank You |
Bronze Member Username: TulipPost Number: 11 Registered: Jun-05 | Help! After downloading the Ultra-283 file my Fortec Ultra will only get satellite 110 and not 119. Has any one else had this problem or did I do something wrong while programing?? Thanks for any help. |
eral Unregistered guest | hay tulip long where did you get ultra-283 file i only have one LB so i only get 110 can you till me thanks. |
DMD Unregistered guest | is there anyone who knows how to change DISH NETWORK receiver(301) key. and what is it? |
Pansat2500aTina Unregistered guest | i downloaded the new bin to the receiver and lost all my channels, i uploaded the channel list from an identical receiver before the flash and tried to download the list but it doesn't work |
Anonymous | For Thill1951 Hi Thill. can you email me @ toantrinh70@yahoo.com I have something want to ask you. Thanks in advance, Hopsing..... |
Anonymous | Can anyone help....please I have pansat3500S, after Sat.Scan, now I see there are alot DOUBLE CHANNEL. I went to Channel Edit to try deleted them. But Channels Name have diffirent number with DN channel guide. If I write down the name, and deleted by name, it is hard to do, and do it forever. Please anyone know how to solve my problem. Thanks in advance. |
New member Username: Mmoura78Newark, Nj Post Number: 1 Registered: Dec-05 | For Thill 1951 HI Thill. can you email me mmoura78@msn.com i have vortex pro 7700. can i use the same keys from pansat? and how to put the keys in vortex? thanks |
Unregistered guest | HI, Anyone, I need to know if I need to use two different LNBs (single or double) to get channels from 110 and 119? |
Unregistered guest | HI, Currently I have a DishPro Twin LNBF on my antena and I get channels from 110 but not from 119, is this appropriate LNB for this set up or do I need two separate (single or double) LNBs to view channels from 110 and 119. Thank You |
New member Username: AnonymousbPost Number: 2 Registered: Nov-05 | hello there, does anybody have any idea about how this key rippers or key grabbers softwares such like key master works? Pls.. |
Gold Member Username: Thill1951akalkPost Number: 1190 Registered: Oct-05 | Plav..the TWIN is a great LNB meant to receiver 2 satellite like the 110-119 with 2 receivers..U should be getting both!...check your remote and disque settings..and with some bins U need to add a dummy channel list..and U must use a channellist made specifically for Dish pro..any others will not work for U.. whatever..all these keymaster etc files are made for 6 yr old to use...just download it to your desk top..then click on the icon it makes whenever U want the latest keys..they are .exe files and U must be connected to the internet whenever U use them.. |
Plavi01 Unregistered guest | HI again I tried to use dishpro channel list but when with the dummy channel list but when I put the channel list to my receiver everything turns green. Anyways, would dual LNB work or do I need two of them put seperately to get the signal from both 110 and 119? |
DMD Unregistered guest | i got pansat 2700E. I lost my manuel of it. can anyone give me pansat remote code for TV and VCR. i got TV= Philips MAGNAVOX and VCR is SONY. |
New member Username: ClistenesPost Number: 1 Registered: Dec-05 | i just put the new bin267 on the 2500 and i just have signal for the 119 need help |
DMD Unregistered guest | i got pansat 2700E. I lost the manuel of pansat 2700E. can anyone give me pansat remote control code for TV and VCR. i got TV= Philips MAGNAVOX and VCR is SONY. |
Anonymous | PHILLIPS TV: 001 003 005 059 070 093 127 164 SONY VCR: 003 031 052 056 057 058 155 |
New member Username: Mmoura78Post Number: 2 Registered: Dec-05 | For Thill 1951 HI Thill. can you email me mmoura78@msn.com i have vortex pro 7700. can i use the same keys from pansat? and how to put the keys in vortex? thanks |
DMD Unregistered guest | thanks, i got tv and VCR code now but how do i apply them. i aslo need instructions to put this tv and VCR code. |
a Lymie Unregistered guest | Hi, I was given a Fortec Star Lifetime Ultra for Christmas. I have no idea how to set it up please can some-one help me with what I need? This would be much appreciated. Regards Pete |
New member Username: Miss_nessa_905Post Number: 8 Registered: Dec-05 | is dere any new keys for pansat 2300A? |
Anonymous | DMD, SORRY FOR NOT INCLUDING THE INSTRUCTIONS. 1. turn the tv set power on. 2. press the remote TV & OK buttons (1-2 second) simultaneously until power button red light appears. 3.aim the remote to the tv set and press the 3 digit specific code number of the tv set. the tv set power will be turned off right away, if not , try another 3 digit code. 4. press the remote tv button to save the program (power button light will blink 3 times). *REPEAT SAME PROCEDURES FOR VCR. |
MBC Unregistered guest | Is it possible to see MBC1,2,3,4,and onetv in Southern Africa? If possible, how can one configure for the channels; where applicalble- frequencies, codes etc esp on the FORTEC STAR Lifetime decoder? |
JOHN BANG Unregistered guest | YT6688 MEGASAT ONCE I CONNECT THE CABLE TO RECIEVER AND BEGGIN THE DOWNLOAD COMPUTER GIVE ME ERROR "PORT NOT VALIT OF INCORECT PORT PLEASE HELP ME WITH THE CORRECT PORTS ON THE COMPUTER I AM USING RS232 |
New member Username: DropeKaty, Tx Harris Post Number: 3 Registered: Dec-05 | i have a for tec lifetime ultra and i need new bin nag2 please |
New member Username: Le74nguyenPerris, Ca Usa Post Number: 4 Registered: Dec-05 | anybody have any new keys please can u post them on the internet so I can get my TV BACK ON.oh i also put DishNetwork keys KEY 0 = 3D 73 19 22 27 5D C2 C9 KEY 1 = 97 96 5A 0C A5 79 27 F9 nothing happend, all channels are still LACKOUT can any give me correct key for pansat 2500A.PLEASE!!!!!!!!!HELP!!!!!!!!!HELP!!!!!!! |
eral Unregistered guest | to linda there are lost of web sites in this forums you sould find the newist key or binfiles for 2500. |
Letmeon Unregistered guest | AF 0C BD 48 D8 51 6D DC FE 44 D6 0C A3 6E 59 42 make sure it is entred at N2 . Noticed key chnge comes after HBO and HBO W disappear, is ther a connection ??? |
cool site Unregistered guest | check out the new www dot undergroundforever dot com |
Bill 1965 Unregistered guest | Okay I'm a newbee so please pardon my dumb asks. Newbee as in I just got the da31 thing 2 days ago and now it it's broke. I guess. When you turn it on it just walks the green light across the front and then shuts itself off. Waits about 10 seconds and turns itself on again and repeats. This a Fortec lifetime ultra that did actually work for about an hour when I tried to move the dish to get a stronger signal. I am guessing from the posts I have read that I need to jtag. thill 1951 or anyone who can help. Do I need to jtag or is something else wrong? Is it fixable? Thanks |
cwcwcw Unregistered guest | What is the different between bin file 1.36 and 1.37? Bugs are suppose to be fixed but did not see any problem with 1.36 bin. Does the epg work any better? Like showing more than an hour of programs in advance. I have Pansat 3500 |
@LstEr Unregistered guest | Hi there, i just wanted to know if my fortec ultra could pick up the european satellite Eurobird 1 from toronto canada. |
New member Username: Snow_whiteEnglee , NEWFOUNDLAND CAN Post Number: 1 Registered: Jan-06 | Hi everyone iam new at this.my boyfriend got me a lifetime ultra for christmas. can someone please tell me what i need to do to get dish net.my receiver is new just took it out of the box, its got a computer cable with it also.anykind of info will be much appreciated (thank you) |
Anonymous | arlene if you were smart you should get your boyfriend to take it back and get a c00Lsat or viewsat. your asking for nothing but headahes |
New member Username: Snow_whiteEnglee , NEWFOUNDLAND CAN Post Number: 2 Registered: Jan-06 | I have read some other questions and answers and i went to a17bar and found some files.i found three files that i think that i can put in my receiver.but the question is i don't know which one is right.does anyone known which one of these three files i should use.-file-28212 or282t2 or 282t3 file.also i was reading about autoroll.can i use autoroll in my lifetime and what is the file number. And by the way i can't take my receiver back because my boyfriend bought it for me when he was in toronto to see family members and we live in Newfoundland.my boyfriends sister as one in toronto and he saw it working and got one.he told me that dishnet tv was great and it was alot of free movies and sports. Thank you anyhow. |
Gold Member Username: Thill1951akalkPost Number: 1322 Registered: Oct-05 | U can ONLY use either 282T or pansat bin 256T safely...and there is NO autoroll bins for the Fortec receivers. 282T bins have keys in them, so U must use the newest one..(newest 20 Dec) 256T bin is very well liked and used but U must manually input the nagra2 keys whenever they change which is 2x a week to once every 10 days Suggest U go read the Fortec area here for about 1 week.. ..and then grab whatever file U decide,they're all right in the link.. |
Bronze Member Username: Le74nguyenPerris, Ca Usa Post Number: 26 Registered: Dec-05 | Hi! sorry I am just new-because my sister bring for my family a pansat 2500a for enjoy a holiday- but she doesn't give us anything BOOK guide show how to down load and update bin... please if you don't mind can you show us step by step how to install and download... thanks we're appreciate. please stop use bad language in here! thanks I did connect between pansat with the cable to PC computer(printer) but I don't know how to intall to pansat software... please help me...ALL MY FAMILY NOW JUST WAIT YOUR HELP.. I JUST WANT TO LET YOU KNOW IAM A LITTLE GIRL AND DON'T KNOW MUCH ABOUT COMPUTER..THAT'S WHY CAN YOU PLEASE SHOW ME STEP BY STEP VERY CLEARLY SO MAY BE CAN I MAKE IT FOR MY FAMILY..THANKS AND HAPPY HOLIDAY TO YOU WITH ALL YOUR FAMILY!!! |
New member Username: Snow_whiteEnglee , NEWFOUNDLAND CAN Post Number: 3 Registered: Jan-06 | Thank you for the help thill1951.we will put in the 282t file for now.could you also tell me what loader i need to use.also you have alot of rude people on this sight.my sister is a teacher here in newfoundland and some of the people on this sight needs to learn how to use english. |
Gold Member Username: Thill1951akalkPost Number: 1326 Registered: Oct-05 | This site is full of filthy trash mouths...and has NO files ...I recommend U use the site which I linked for U or any other site..there are software loaders at the link I provided to U.. |
Gold Member Username: Thill1951akalkPost Number: 1330 Registered: Oct-05 | Fortec flashed to the clone safe pantsat bin 256T aka 256cV3 now for flashing: downloader program required: here is the original flash for your ultra,flash this file first everytime b4 you reflash a new fix: here is a file that gets dishnet and allows manual key entry that is safe for your ultra: here is a program that will retrieve the latest keys that need to be entered to recieve channels: ok now for flashing your reciever: first unzip all of these files into a folder with the name of your choice(fortec files?) second start the downloader program BLACkLIST UPDATER verify the com port setting that your 9 pin cable is connected to on you computer(com 1 is default) connect other end of 9 pin cable to reciever's rs232 port plug in recievers power cord with the switch on the rear of reciever in the off position. click select bin and find where your dish files are saved and open the 272 file. switch power switch in rear of reciever to on position noting front panel display,when you see the first - of the - - - - lights begin to move across the front display,click Write Bin. the progress bar will now begin to move in the blacklist updater and continue to count up to 100% then change to flash burning DO NOT do anything during this time until you see a new window saying flash complete and your reciever restarts. when the reciever has successfully restarted turn the power switch off in back and click select bin again and find and open 256cv3 file. when reciever has been off for a minimum of 5 seconds you can turn the switch on again and write bin when you see the first - light on front pannel of the reciever,same as before DO NOT do anything until flash complete window opens and reciever has restarted. turn power switch off again and connect reciever to tv and dish,set up your configuration for switches and sats in the instalation menu,scan your sats. now start the keymaster program and record the keys given for dishnet. Procedure for manual key entry for 256cv3 file: On your remote click the menu button. Scroll down to parental control and click ok. Then scroll down to second pin and enter 0000. Then scroll down to Nagravision and click ok. Then where provider ID is use the right vol.button to scroll right to Dishnet Work. Then scroll down to Key Number. Then Scroll right 2 times and you will then be in Nagravision2 mode and key 00. scroll down to key line. Enter the key 00 there. Then scroll back up to Key Number. Then scroll right one more time to key 01. scroll down to key line. Enter the key 01 there. Then click ok to save. Now click the exit button 4 times and you should have TV. |
New member Username: Puzzle1Post Number: 1 Registered: Jan-06 | I have fortec lifetime i have sat.110 & 119. I need to find a local echostar 1 and 2 for INTL channels on 148W. Anyone knows where to get this file? Please help |
Bronze Member Username: Le74nguyenPerris, Ca Usa Post Number: 31 Registered: Dec-05 | yeh! I did..but my tv until now black and white!, ok-- sorry I am just newer-- I just got this reciever only one& two week.. I still need help..don't you got it! Iam still looking for a software for my receiver pansat 2500a.. if you think you can help me..iam very appreciate! |
Bronze Member Username: Le74nguyenPerris, Ca Usa Post Number: 35 Registered: Dec-05 | can you help pleassssse,, How come I download with update my receipver-- but now I turn my tv on & I don't see anything. I turn on my receiver, I go to installation, I click ok! afterthat i can not open chanel edit with parent control.. can you please help.... Now I just blind scan but still nothing... PLEASSSSSEEEE HELP I CAN NOT OPEN THE CHANEL EDIT AND PARENT CONTROL...HOW COME? DO I DO SOME THING WRONGS???? |
New member Username: AjbPost Number: 1 Registered: Jan-06 | are you pointing dish at the right satellite?what is your signal like? why are you trying to open channel edit if you haven't downloaded anything?What steps have you taken?What bin number are you using?What is your antena set up in your installation?There is alot of missing info and its really hard to help you if we don't have alot of info. |
Gold Member Username: Thill1951akalkPost Number: 1337 Registered: Oct-05 | She needs to read the Pansat set up guides posted everywhere...and then CLOSELY follow the step by step instructions!...hardest part is aligning the roof dish...she should be using clone safe 267 bin with autoroll....the setup is simple , about a 20 minute job.. Simple PanSat FAT Receiver set up Guide **** I hope this instruction will help you get started: Read the instruction and understand all the procedures first before you starting to flash your receiver. ========================================= Before we getting start, you have to down load all the software you will need and install them. Down load the file you need from below link, then create a folder, and save as any name you want ( I name my Pansat Utilities_Programming), then unzip the file into the same folder. Pansat FTA Loader: Get your PanSat loader here PanSat FTA N2 Flash: Get your PanSat FTA Newest N2 Released Channel Master: Get it here ============================================ Receiver Software update: 1. Connect the serial cable to the receiver and Comm #1 or Comm #2 SERIAL port of your computer. Double check and make sure the cable is securely connected. Note: Pansat 2700 & 3500 use RS232C null modem(serial)cable and Pansat 2500 use RS232C straight through serial cable 2. Plug in the receiver power core, make sure the switch is turn to "ON " from the rear panel, Then turn the power ON with remote control or from the front. You have to wait for receiver to boot up and indicated ON. 3. Run the Down loader GTRom Loader from the new created folder. 4. Click the BIN FILE button, browser and select latest BIN FILE, then click the Open button. 5. Click the Download button, wait until the Download Completed. Watch the LED on the receiver, it should reboot itself, wait until receiver displayed ON. 6. At this point; You are done with the software update. You can turn off power, then disconnect it from the PC. ================================================== === Receiver Configuration set up With the Receiver unplug 1. Connecting all the RCA cable from the TV to the receiver, and connect RG-6 Cable to the receiver, then Plug in power cord on the receiver. 2. You should see the Language Menu on the TV screen, select English. 3. "CAS SYSTEM" set up, just following the 3A, 3B and 3C steps 3A). Press menu, scroll down to select Parental Control then press OK. 3B). Scroll down to PIN #2, then enter you 4 digits password.0000 If you enter correct PW, it will take you into the CAS SYSTEM menu windown. 3C). In the CAS SYSTEM menu, scroll down to SET DEFAULT KEY, then press OK. Then exit to main menu page. In the future; if you have to edit the Dishnet key, just following the step #3 to get into the CAS SYSTEM menu. 4. From the MAIN MENU: selecting INSTALLATION then Antenna setup Option. These are my dish set up and DiSeqC multi switch configuration; DiSeqC #1 SuperDish Echo9-IA 13 Dishnet 121 DiSeqC #2 Echo8.6/Ku 110W, DiSeqC #3 Echo7/Ku at 119W Satellite: ECHO 9(121) same as dish 105 Lnb type-Standard Lo freq-10750 22khz-OFF DiseqC- #1 Skew: O TP: leave it as is Positioner-Disable. Satellite: ECHO 6,8(110) Lnb type-Standard Lo freq-11250 22khz-OFF DiseqC-#2 Skew: O TP: leave it as is Positioner-Disable. Satellite: ECHO 7(119) Lnb type-Standard Lo freq-11250 22khz-OFF DiseqC-#3 Skew: O TP: leave it as is Positioner-Disable. 5. Check the signal and Quality level highest as you can (adjust the dish slightly to improve the signal strength). If you get no quality level on transponders, try others before giving up, because not all TPs are transmitting, If necessary Re-aim your dish if still not getting any quality signal 6. Press the Exit button, press OK to save setting, the back to the Main Menu 7. Go back to the Installation Menu 8. Goto SATELLITE SCAN or BLIND SCAN, press OK, select the satellite to scan. you have to scan all the satellites have, once it complete, you should be able to watching TV ============================================ Customize your own channels with Channel Master 1. Hook up you box to the PC again. 2. Run the Channel Master, upload the channels list to the PC. 3. From the Channel master, you can edit or delete the unwant channel, save it, then load it back to your box. Go to lyngsat.c*om for you satellite channel information Note: Channel Master has the help menu, just look up on the top tool box. |
New member Username: AyassinePost Number: 1 Registered: Jan-06 | To thill1951 You are very intelligent and know your stuff, but it seems like information overload. For example, I bought the pansat 3500. I tried to follow the discussion to figure out how to program it and I got very confused. You all assume people know what you know and not everyone does. Ok, then, the bin file, the codes. When do I need to install a bin file, and why? what version of bin file? what is a rollback? because the recevier is virgin, do I need to install a new bin file in order for me to enter the new key, or just enter new key? how do I know this information? It is all confusing, and we need to simplify it for readers like me. |
Anonymous | Hey thill1951, I saw her post at dsstester. Same old post she didn't mention anything about her set up,all she saying is her tv got black screen.I thought may be you seen her tread when you were there this morning.I didn't mention your name but I basically let everyone know that if you couldn't walk her throught the steps I don't think anyone else could.Check it out.It is under pansat 2500a need help set up. |
Gold Member Username: Thill1951akalkPost Number: 1340 Registered: Oct-05 | Yes I saw Linda's posts the past few days at dsstester..The above steps for ANY receiver cannot be any simpler.. For U that do NOT understand,its because U haven't read anything, so its all Greek to U..U must read first and grasp a little of this on your own...U cannot walk in here and "just do it"! BTW...channel master and channel lists are an option and NOT a necessity!..Receiver software update and Configure is all U need to do, along with correctly aiming your dish.. For the Pansat 3500..use the latest 137 bin...autoroll means the "keys" (dishnet secret codes) will automatically be received and inputted into your receiver...U do Not have to find the "keys" and manully input them..Bin file is the software that has codes that unscramble the Dishnetwork signals which are sent scrambled so people can't watch for FREE, so U can watch TV...If a bin file is working fine for U ,then no need to change it..Virginnreceiver should be loaded with the factory flash/bin file first ,then the latest autoroll (bin 137 for the 3500) |
New member Username: AyassinePost Number: 2 Registered: Jan-06 | <quote> I am wondering, Doesn't the 3500 come loaded with the factory flash/bin file? if not then where do I get it from ? I read your instructions about the Antenna setup and I was curious to know if that setup works with the Superdish? When you said that the keys are good for all the receviers, are you talking about the bin file or are you talking about the keys only. Also, how do I pick the 137 bin from among all the bin files outhere? Thanks you have been really a lot of help. |
Gold Member Username: Thill1951akalkPost Number: 1344 Registered: Oct-05 | Keys are same for all receivers..bins vary by receiver make/model..For pansats the best site is [link removed] ..they have a 3500 discussion area and a 3500 file area..also have a newbie area too for FAQ...that config works on any dish |
New member Username: AyassinePost Number: 3 Registered: Jan-06 | thill1951 Thank you, you have been great help. |
Bronze Member Username: Le74nguyenPerris, Ca Usa Post Number: 36 Registered: Dec-05 | Thanks thrill1951 I will follow your step by step, now. I hope I can make it! |
Anonymous | thanks thill bull answering your own post again you idiot. |
New member Username: Snow_whiteEnglee , NEWFOUNDLAND CAN Post Number: 4 Registered: Jan-06 | Thank you thill1951 for your help.me and my boyfriend did what you said to do.we took alot of time doing it but we got it done. this is the best gift that i could get for christmas.we are so happy with this receiver that some of our friends in newfoundland want to get one also.i thing that this type of receiver dss is going to make it big in newfoundland.will again thank you very much for you help and God bless you and your family. |
Anonymous | Hi Do anyone know what to use to receive Direct- TV Latino, Can you use a Pansat 2700 and where do I get the program |
Silver Member Username: ThehitchFla. Post Number: 285 Registered: Oct-05 | Ha Ha; Anon, I see UR registered here, so you are either spoofin us or just visiting from another planet. All the info you need is @directtv.c*m. |
New member Username: ThillisbackPost Number: 5 Registered: Jan-06 | U must use a DirectV receiver toget DTV and U must subscribe! Arlene...good luck...in the future , I would NOT suggest a Fortec Ultra or any Fortec receiver..get either a Pansat 3500, co*olsat 4000/5000 or viewsat 2000 platinum..they have MUCH more software support,especially the pansat 3500 or viewsat.. |
New member Username: AshkitPost Number: 5 Registered: Dec-05 | I have single satellite dish with dual output lnb pointing at 61.5W. I used a satellite finder to trace the signal and was able to get signal but it sits at 78%Level and 40%Quality. I tried to align the dish different ways but did not succeed in getting 80-90% Quality. I am using fortec lifte time ultra receiver with 282t bin installed. Any help to get 80-90% signal would be appreciated. |
Gold Member Username: Maple_leafPost Number: 1207 Registered: Apr-05 | School's out . LMAO |
Anonymous | I have pansat 2500a sat receiver. The picture freezes momentarily. It happens to all channels. Cause or solution. |
Bronze Member Username: ThillisbackPost Number: 47 Registered: Jan-06 | Thats very common when using software with electronics..especially satellite equipment, either FTA or DN with plastic ..some files/bins are more apt to freeze than others..no solution,except try another file..and clean your receiver of any old memory and corruption |
Silver Member Username: HamtecPost Number: 349 Registered: Jun-04 | Hey thill hows it going!!!! Long time no talk!!!! |
Desperate Edgar Unregistered guest | Hello guys, I have this big problem: I have a Fortec Lifetime Ultra and I downloaded a bin file from dishnewbies.com that was supposed to let me get both Bev and DN, but after "downloading complete" my receiver showed something like a "+6" on screen. I turned it off on the back switch and it never turned on again, not even the ----- lights, absolutely nothing, and of course when I now try to download the previous bin that was working perfectly it says "download fail" because it doesn't have power. Is there something I can do to fix my receiver, like a boot or something, or do I need a person to repair it? I'd really really apreciate any good suggestions you may have. Thank you guys. |
New member Username: LklivesPost Number: 7 Registered: Jan-06 | Jtag...or the Fortec Black Death repair kit file...and Jtagging a Fortec and pansat 2500 are done identical.. [link removed] |
Desperate Edgar Unregistered guest | LK, the problem is that my knowledge doesn't go that far as to open my ird or build a cable as the one I think I will need. If it isn't too much bothering you, would you explain in simple english what is Jtag, so I can know if I am capable of doing it or not? Thanks man. |
Bronze Member Username: LklivesPost Number: 12 Registered: Jan-06 | Open your IRD (receiver) is about 4-6 screws and U need a screwdriver oe even a beer tab might work..sometimes soldering a few spots is required, sometimes not...nobody has any knowledge about anything until they try it..could U swim before U tried?..NO!...ride a bike?...NO..this is NOT rocket science..IF U can read, comprehend English and have 2 hands and eyes, then U can do this.. A person is ONLY a failure when he stops trying... BTW...most electronics shops will Jtag it for U.. |
Desperate Edgar Unregistered guest | Oh I see, you're implying that I must open my ird and sold the first thing I see. Why didn't you say so before? It's so easy! Maybe I could just melt the circuits to make my life more intersting! You know something? I was just asking you for a guide, not to solve my life. Let me tell you that your big mistake is asuming that everybody has the same abilities (not capacities). Have you heard about "empathy"? Why don't you try some? Not everybody has the time and the resources as you do, to have a full time hobby. Some of us have to work for living. Anyway, thanks a lot for taking the time to dedicate me a sarcastic answer. It makes you a grand person, and excuse me if my ignorance offended your wisdom. I see that you're an expert in electronics AND in lecturing people about success. Bye man. |
Unregistered guest | i have a pansat 2500A, it just show "On" all the time and i cant figure it out how to show the numbers |
Anonymous | Can someone guide me to get back the romanian lost chanels from 97.5 (T5)Sat/Fta please? Realy appreciated if you will explain for a beginer... Thanks for all |
Dorina Unregistered guest | I have a Fortec Lifetime Ultra. Can someone guide me to get back the romanian lost chanels from 97.5 (T5)Sat/Fta please? Realy appreciated if you will explain for a beginer... Thanks for all |
Myhair Unregistered guest | Hello Thill1951, I think you are the one is going to have an answer for me. I bought a Pansat 3500S but I have no idea what kind of software I need to use to watch channels on 110,119 and 61.5. The only thing I have is two dishes one is point to 110/119 and the other to 61.5. Please, please tell me what should I do and where to download the software and what exactly I have to do after that. Thank you so much and happy new year. P.S It would be nice to hear from you soon. :-) Myhair |
Anonymous | Hi Everyone, I'm a beginer to this and I do have the same problem as Myhair. I would realy appreciated if any of you guys explain to me what to do to be up and runing. Thank you to all of you. |
cool site Unregistered guest | check out www dot undergroundforever dot com |
Bronze Member Username: LklivesPost Number: 53 Registered: Jan-06 | U both have 1-2 weeks of reading...U need to align /aim the LNB's (eyes) on your dish towards the satelites U want...Dishnetwork 110-119 are most common..then U need to run RG6 cable to your receiver, and make sure U are aimed correctly and "scan" each satellite..next U need to configure your receiver..now install a disque switch between your LNB and receiver (closer to the receiver is better)...now flash the lateset software(bin 136 for the 3500) and upload it into your receiver...set the default keys...press SAT on remote and select echopackage..watch TV.. So go to |
