Alpine or phoenix gold
Username: Kasadude
Highland, Ut. Usa
Post Number: 75
ok so i am just about to buy an amp i have a budget of 250 i have found both an alpine M605 and a Phoenix Gold 600.1 for similur prices (the PG is a little bit cheaper) I was wonder which of these would have better SQ and which one is would last longer/give out the best power etc.
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 3925
the pg 600.1 is better. It is more versitale and i think it is rated at 13.8v
Username: Kasadude
Highland, Ut. Usa
Post Number: 76
ok thanks i will get that one i guess than, thanks for the help
Username: Joebruce
KY U.S.A.
Post Number: 275
Look at xtant you could find one for around that price that puts out 600 watts and they are much better amps than Alpine or PG.
Username: Jonathan_f
GA USA
Post Number: 5340
Typically you can find a Kicker 600.1 around that price as well.
