Poweracoustik vs. Infinity
Username: Jbump
Nebraska City, Nebraska USA
Post Number: 14
Which of the two have the best sq but can still pound a, Power Acoustik FXB-12 or a Infinity Kappa 120.3SE
Username: 54danny54
Betsy layne, Kentucky.. USA duh
Post Number: 1484
infinity for sq PA for spl
Username: Jbump
Post Number: 15
does the PA FXB-12 still have alright sq?
Username: Rovin
Trinidad & T...
Post Number: 4498
every1 here says All of PA's stuff sux
so better u look @ some alpine type Rs or X or some Diamond audio subs both are pretty decent & don't costs a ton ..........
Username: Jbump
Post Number: 16
I think i'll probably get a pair of Alipine SWR-1242D since they don't cost much more than PA's stuff..
Username: Rovin
Trinidad & T...
Post Number: 4501
thats exactly what i have & it sounds darn good .......
Username: Islandboy808
Mililani, Hawaii US
Post Number: 467
make sure u get the dual 4 if u wanna run it at 1ohm.
if u get the dual 2s u gotta run it at 2 or 8 ohm.
so if u have an amp make sure that its compatible with the subs your buying.
Username: Jbump
Post Number: 20
I got a 2 channel amp 2 ohm stereo stable so i'll prolly get 4ohm DVC for each channel
Username: 54danny54
Post Number: 1487
lol rovin
"every1 here says All of PA's stuff sux"
i never said i did:-)
