i have an alpine type e 10 inc sub with a alpine mrp m350 mono amp. any tips or suggestions on how to maximize its performace. oh yeah the type e sub is a 4omh coil sub. anymore info needed let me know.
the subs specs are as follows: the type e specs are » 10" 4-ohm subwoofer » Kevlar-treated pulp woofer cone » high-excursion Santoprene rubber surround » dual oversized Nomex spiders » frequency response: 32-1,000 Hz » power range: 50-250 watts RMS » peak power: 750 watts RMS » sensitivity: 87 dB
the amp specs are as follows" » 200 watts RMS x 1 at 4 ohms (350 watts RMS x 1 at 2 ohms) » low-pass filter (50-200 Hz, 24 dB/octave) » variable Bass EQ bass boost (0-12 dB at 50 Hz) » subsonic filter (15 Hz) » MOSFET power supply » preamp- and speaker-level inputs » blue power LED » extra-large gold-plated terminals 700 watts max power
