Hookin up 1 sub/ 2 tweets to a 2 channle amp
Username: Fordpimp99
Arbuckle, CA US
i dont know what 2 do. im running a L7 12" bridged and my filtered tweets by each channle on an audiobahn 800w amp. my amp is hooked up through front speaker RCA jack on deck in stead of sub RCA. when i switch to sub RCA or low pass on the amp to get rid of the mid sound in my sub (for clean loud bass) my tweets dont work.
do i need a low pass filter to run after the amp, to the sub?
my sub is also louder though front RCA rather than sub RCA. why?
answers to these ?s would be a big help.
Username: Tjmutlow
Post Number: 879
first off those tweets do not need to be on that amp, if you have that bridged, is it a dual 4 ohm sub, is so you have already overloaded the ohm capabilities of the 2 channel, and yes when you take the switch to low pass, all you get is bass, if you want a better sound run your tweets and internal speakers to a 4 channel, stereo mode.
