Mitsubishi tv help
Username: Pinto_dude
I just picked up a mit. VS-685R tv. The person said the convergence board was bad. I pulled the board and found the L801 coil was burned through and solder points were bad. I fixed as many solder points as I could find. my problem: I can't find a place to buy a L801 coil and Is there anything else that probably went bad and should be replaced while I'm at it.
The convergence test button shows 3 color lines. They cross, but not over lap. Both the blue and green are twisted. Not strait lines.
Please help. Thanks
