Quick head unit installation question...
Username: Quig
Pittsburgh, Pa Us
Post Number: 42
k i want to take the factory stereo out a dodge spirit 1995.... and put a head unit in.... will i need any extra wires or harness or w/e or do i jsut take it out and plug it in?
you'll need to buy a harness for your specific car that plugs into the stock wires. then the wire colors on that harness will match the wire colors from your new cd deck. then you can always get a mounting kit if you want a nice clean installation, sorta like this one
http://www.crutchfield.com/S-vXpiDI39HFf/cgi-bin/ProdView.asp?g=112200&I=1421235 B
I don't know if thats the specific one you need but you get the point.
Username: Infinity_addict
Santa Rosa, California USA
Post Number: 227
you typically want 3 things: a wire harness that connects to your car and has a universal plug at the other end, a wire harness with a universal end and an end that matches your brand stereo, and a dash kit so your stereo fits in nicely.
