Username: Berns231 Post Number: 14 Registered: Dec-05
Sunday, January 01, 2006 - 19:46 GMT i was thinking about either getting 2 type R's or 1 type X. IM not sure about what to get and what will sound better in sq and spl.
Username: Help2 Post Number: 12 Registered: Dec-04
Sunday, January 01, 2006 - 19:54 GMT what sort of amp will you be using
Username: Rovin Trinidad & T...
Post Number: 4368 Registered: Jul-05
Sunday, January 01, 2006 - 19:55 GMT ask Chad Lee - he has done both combos . i think what he told me is that 2 Rs does beat 1 X though .......
Username: Berns231 Post Number: 15 Registered: Dec-05
Sunday, January 01, 2006 - 19:56 GMT i was thinking about getting the orion 1200d or kicker 1200.1. Or if anyone has any other suggestions
Username: Help2 Post Number: 14 Registered: Dec-04
Sunday, January 01, 2006 - 19:58 GMT cone area is king. on that power Id do 2 type r anyway
Post Number: 4369 Registered: Jul-05
Sunday, January 01, 2006 - 20:01 GMT those 2 are pretty good , chad had that kicker 1200 amp but sold it & is now running 2 X with 2 JL1000/1 ..... i have 2 Rs which sound pretty good even with little power & i'm about 2 install tommorow a MB quart raa1000 amp on it ....
Username: Berns231 Post Number: 16 Registered: Dec-05
Sunday, January 01, 2006 - 20:09 GMT what do u have powering your R's now?
Username: Jakeyplaysbass St. Louis,
MO
Post Number: 412 Registered: Jul-05
Sunday, January 01, 2006 - 20:25 GMT the type Xs have better SQ than the type Rs. ive tried both and its a noticable difference. for what you are looking at i would go with the type Rs tho. it will sound louder and still maintain a good amount of SQ.
Username: Phuktupbasshead Scottsdale,
Arizona
United State...
Post Number: 365 Registered: May-05
Monday, January 02, 2006 - 09:38 GMT what's the optimal enclosure specs from your all's experience with the type R's to get the most spl out of them?
