Which are better
im buying subs and i want to know if i should get 2 alpine type r's or should i get one type x. whick will produce more bass?
Username: Baseball1187
Columbia, SC
Post Number: 452
I'm not sure... we dont generally see a lot of talk about Type Rs or Xs on this forum. somebody will know though
Username: Insearchofbass
Post Number: 4118
from what I hear installs being equal the type x will win in spl
ok so what would you do? go with like one x or 2 r's. i just want a sub that wu=ill make a lot of bass. i=im new at this and i had two p2 and they blew. i would like subs louder than those and in 250 dollar price range. thanks guys
Username: Rovin
Trinidad & T...
Post Number: 4402
are ppl just clowning here or are there ?s legit !??
https://www.ecoustics.com/electronics/forum/car-audio/186724.html
are there any other subs in that price range that is better than the r's.
Username: Camaro823
British Colu... Canada
Post Number: 263
I may not have many posts, but i've been here long enough to see many posts on this topic, just take a look around the forum and your guaranteed an answer.
Username: Lexuscoop
Post Number: 505
go with the type r's. the x's will win in SPL one on one, but if you go with two R's they will be louder
Username: Jakeyplaysbass
St. Louis, MO
Post Number: 414
type Xs are SQ subs. type Rs are SQL subs. The only way the type X would win with SPL is if it had more power than the type R.
