Username: Boneywankenobi Maryborough,
QLD
Australia
Post Number: 5 Registered: Dec-05
Monday, January 02, 2006 - 01:53 GMT Hey. I have a problem with my "bridgeable" Earthquake TNT-300 amp. I have tried bridging both channels on the amp...but when I do the power light dims and flickers and I lose all gain and frequency control. Almost appears as though it's overloading it or something??? Any ideas?
Username: Tjmutlow Post Number: 795 Registered: Sep-05
Monday, January 02, 2006 - 04:33 GMT what are you tring to put on it, it better be a single 4ohm sub, or 2 dual 2 or 2 single 8 ohm subs, if not, that is prob the problem.
QLD
Australia
Post Number: 6 Registered: Dec-05
Monday, January 02, 2006 - 04:50 GMT Thanks mutlow I might look into that, it's a 12" Sony Xplod by the way. So maybe it isn't 4 ohms.
QLD
Australia
Post Number: 7 Registered: Dec-05
Monday, January 02, 2006 - 04:57 GMT Well looking through the Sony website all of their subs appear to be 4 Ohms. Mine is a little older but I'm guessing it's probably 4 as well.
Username: Dustin3 Tigard,
Or
U.S.
Post Number: 196 Registered: Oct-05
Monday, January 02, 2006 - 04:58 GMT well tell us the specs
Or
U.S.
Post Number: 197 Registered: Oct-05
Monday, January 02, 2006 - 04:59 GMT is it dual or single voice coil?
