Need Recomendation
Colby
I have a 1993 Mercedes 300 E 2.8 with a Thunder 8500 15 inch in the trunk. I have plenty of power for it but its just not loud enough for me. I was wondering if there was a way to get the bass from the trunk into the car where i sit better. I was thinking of getting a port somewhere to open up the trunk with the rest of the car. Withought buying more subs, or a more powerful amp, what would you do?
Username: Killerzracing71
Fredericksbutg, Virginia United states
Post Number: 240
im sure that would help i saw somewhere someone had a truck i wana say a avalanche(which doesnt seem right since u can drop the mid gate) or a bmw. think it was the beemer they cut a port out to allow bass to get in, dont now what specific req's are nessasary to make it sound decent though
Colby
Ok thx. What do you think of the sub i got, the 8500?
