Amp for KICKER woofer
Username: Montana86
I have a CVR15 05 model, its 1000w peak and 500rms and its daul 2ohm not dual 4 ohm. What kind of amp should I buy for this woofer, I was looking at mono amps because the CVR is the only woofer I wanna drive. I'm also new to car audio and ohms are kinda confusing me. I'm not sure how my woofer should be wired in series or parallel.
Username: Theelfkeeper
Stockbridge, GA USA
Post Number: 773
idk if the kicker KX 600.1 is 1 ohm stable.
orion 600D would be 600 at 1 ohm
Hifonics BX605 is 600 at 1 ohm
JL 500/1 is 500 from 1.5 - 4 ohms
theres ya a couple to start with
Username: Dustin3
Tigard, Or U.S.
Post Number: 198
is it 1 or 2 subs??
if two subs you should use a mono amplifer and for one sub, use a 2-channel amp. it is basically backwards because u would think mono amp would go to one sub and 2-channel go to 2 subs. but thats wrong
