You guys got any suggestions
Username: Clacla100
Tallahassee, Fl US
Post Number: 7
i just got rid of my old setup and im looking for a good amp price range 200-280$ im looking for around 1000 rms at 1 ohm.
you guys got any ideas?
Username: A444w444m
Post Number: 174
well for 390 u could get an re12.1 amp, 1200 watts at one ohm, its more like 1300- 1400 though, probably
Username: Alex_f
Lawrenceburg, Ky Us
Post Number: 490
well, if u want a good amp u might want 2 spend a little more. adleast $330
Username: 54danny54
Betsy layne, Kentucky.. USA duh
Post Number: 1464
try hifonics BX1205D...it will put out 1000 at 1 ohm...also it should cost under 200
Username: Clacla100
Tallahassee, Fl US
Post Number: 8
yeah i can up my range into the mid 300's. One of my friends is selling an eclispe ti but if i dont end up getting that im considering a type x.
Username: Clacla100
Tallahassee, Fl US
Post Number: 9
thanks for the advice so far, but does anyone else have any ideas?
Username: Baseball1187
Columbia, SC
Post Number: 440
MB QUART RAA1000 :-)
Username: Killerzracing71
Fredericksbutg, Virginia United states
Post Number: 241
yes raa 1000 i own one blew my first sub(do to my lack of knowledge)@ 1ohm only running it at 2ohms now 500rms sounds good, cheap amp well now after the sale. good luck finding one for 300$ though i havent seen another one that price after the crutchfield sale in the summer
o two old amps that people have to make 500 to each vc or something like that would make a cool setuo
Username: Clacla100
Tallahassee, Fl US
Post Number: 11
i just looked at the RAA1000 and i noticed its not mono would that make any difference in the quality, and wouldnt it heat up faster and not be able to run as efficiently as a mono?
Username: Rovin
Trinidad & T...
Post Number: 4390
oh but it IS Mono !
i bought 1 a few wks back when it was on sale but haven't tried it out as yet maybe 2morrow or day after when i hook my other stuff up .......
Columbia, SC
Post Number: 446
cory
I have the RAA1000 and I love it... i wouldnt be surprised if it's pushing 100w+ over the RMS... it's pounding my SEs
Username: Rovin
Trinidad & T...
Post Number: 4392
I'm gonna pushing 2 12 Rs with mine....Upload.....
Username: Clacla100
Tallahassee, Fl US
Post Number: 12
ok you guys convincend me im getting the raa100 thanks for the advice
Username: Rovin
Trinidad & T...
Post Number: 4393
well actually i'm sure what happened is that prolly the 3 of us got it a few mths back from Cruthfield when they had it on sale $299 Shipped ! - ALOT of ppl bought it back then cause its $80 off reg price & s/h was incl'd ............
Username: Clacla100
Tallahassee, Fl US
Post Number: 13
i found it for a good price so im good... 260$
Username: Clacla100
Tallahassee, Fl US
Post Number: 14
didnt bump for some reason...
Username: Rovin
Trinidad & T...
Post Number: 4396
oh sweet price ! - i was assured on this forum by both jonathan/isaac that its a good amp b4 i bought mine so even though i got it a while now i'm not worried about it being good ......
Username: Clacla100
Tallahassee, Fl US
Post Number: 15
would i need some 2 gauge wiring to run this thing or would it do fine with 4
Columbia, SC
Post Number: 450
you'll be fine with 4guage as long as the run isnt tooo long. Look at knukonceptz.com for wire. Their 4guage is actually 3AWG and it's pretty cheap
Username: Rovin
Trinidad & T...
Post Number: 4400
i installed 2G to be running mine cause u have 2 take into account ur other 2 or 4chan amp
use this guide
http://www.the12volt.com/wiring/recwirsz.asp ........
Columbia, SC
Post Number: 451
drop the extra $$ and get the 1/0!
Post Number: 242
but the 1/0 prolly wont fit it took alot to get 2ga in mine
Username: Rovin
Trinidad & T...
Post Number: 4409
thats why u get a dist block with 0G running up to it from your batt & then u could go down to 2G if amp less than 5ft away from dist block .......
