Archive through January 22, 2006
Closed: New threads not accepted on this page
  Thread Last Poster Posts Last Post
Few things to get rid ofty mutlow1
Pioneer (6x8) 4 way speaker opinions?Jono11885
Are there any tweeters made for SPL?Pelon4
Why would the Infinity Reference sound better than the Perfects?David Brunner10
5.25 or 6.5 and whyTyler6
Not enough channelsty mutlow3
Sweet Deal 6-$700 Compsmikechec91
How Long of a Break-In Time??????James Longo3
I have no crossoverOptidriven8
Decent 5.25" speakersTyler8
RE or Ascendant ComponentsJoe Smoe10
6x9s in boxes?matt rogers4
JonathanChad Lee10
Which speakers should I get?alteraudiousa20
Enclose size for xr 650sTrevor Eaton4
Cheapest place to get SPX-177R Type X 6.5" componentsTyler2
Wiringnathan6
I need some 2 or 3 way speakers|\/|aTT |F6
Which would float my Boat?MPH3
Speaker poweringmat hooker3
Alpine or Pioneer/\/\ike3
Silk or aluminum dome?mikechec920
Cracking soundilya iaskevich1
Changing 5x7 into 6.5Jeffrey Both4
Help making 5x7 into 6.5Jeffrey Both1
Wiring monitor speaker to car deckchris castillo1
Quick question for the knowledgableBrandon S4
2-way HelpTyler12
Tang Band Group Buyalteraudiousa1
5x7 to 6.5mat hooker7
Help with speakers.lucas beckner6
Help a girl out|\/|aTT |F19
Speaker wiring + -mat hooker6
New generation Digital Amp + MB Quart ...DistortionBryan11
Speaker powering???Brandon2
Mb Quart or ??Craig D1
Treo?!?jake papa2
6x9s or 6 1/2s???bassman36
6.5 into a 4x6 hole? help me!lucas beckner3
HI/LOW Pass converter for Bose Systemlucas beckner2
Which one of these speakers are better?SPLSQ1
Cadalliac deville bose audio system with alpine subsMichael3
NE decent 4" speakers?alteraudiousa4
Sony LoversPelon5
Dynaudio System 240GT Chad Lee1
Need a boxSteve Magg1
Infinity kappa Vs referenceTheresa3
Need suggestions on speaker upgradeTheresa11
Jonathan HELP ME.Jonathan10
Mmats Pro Components/Jonathan or someoneVincent4
How do you wire kappa 6x9 693.7i (dual coil) with kicker 600.4 amp...ty mutlow2
95 suburban rear or middle doorsjrau1
Best 5x7 SpeakersAnonymous4
Will I be underpowering my speakers?Optidriven20
Infinity Kappa 3-way Speakers?ty mutlow4
6X8 SpeakersMark D Barnfield10
Speakers are not getting any juicety mutlow4
New Hybrid Audios Launched.Jonathan9
If anyone can help me outJonathan6
8 speakers 4 channel ampThomas White19
JL Audio XR SeriesJonathan6
System Setup w/ rear fill problemMark Gemina4
Help or suggestionsJake Davis5
Subs are not getting any juice.smartin1
Will this sound good?Travis_k3
SoundstageGlassWolf2
Diamond M6 Component problemVincent2
I need help anyone who knows about diamond audioVincent4
I want to replace 6x8 helpty mutlow2
4" vs 6.5'sty mutlow2
3-way componentsChristopher Lee11
Best sealed box for a 10'Anonymous2
Components for jl audio 300/4killerzracing719
89 maxima speakersBryn Mountford1
Speaker sizesOptidriven2
Little HelpJake Davis6
Good Sounding Mids and Highs12 oUnCe MouSe3
Bridging helpMiguel Reyes2
6x9 alpine type RMiguel Reyes1
How do i extend the wire form the tweeterschris2
NE decent 4" speakers?Jonathan12
Are the jl zr650s better than the xr653s ?Jonathan23
Little HelpMiguel Reyes1
Should you build an enclosure for components?alteraudiousa4
Replacing 3000gt speakersdrewg3
WHats the difference between coaxial and component speakers?GlassWolf3
How do you hook a head unit up in a house?STEVENNNNNN3
Glasswolf or Jonathan / Infinity Kappy Perfect 6.1 questionMO21
I need help glasswolf or any1 else with....GlassWolf8
Bassy 6x8timm1
Can Crossing Wires Damage Speakers?scuba steve5
Should i or shouldnt I Vincent4
Components!!!Vincent6
I need some componentsVincent8
Best 6x9's on the marketalteraudiousa2
6" curiosityty mutlow2
Box issues help Anonymous1
Pioneer or jbl 6x9's?Pao Trifyllara5
Orion c series 6x9 and 6.5 coax for sale.ty mutlow2
1992 Explorer help please.Kevin6
