can some1 tell me how do u connect a ps2 to a dvd player wat coreds to i need
yo what you need to do is make sure is has a/v in the polaroid portable dvd player Polaroid 7" Portable DVD Player (PDM-0723) has it. Then you make sure u have the a/v cables for the ps2 then you go to radio shack and buy phono plug coupler its like 3.99 it doesnt matter if its the gold series or not . Once you have that u just connect both sides to the coupler. For example the portable dvd player comes with an a/v cable red, white, yellow but they are males so u would connect the re, white and yellow to one side of the coupler and then connect the same color from the ps2 a/v cable to the other side make sure the a/v in switch is on and bam its done. I have done it and it works just make sure u have a/v in not a/v out on the portable dvd player.
