Amp produces no power
I have a Sony Xplod amp.Model xm-1002hx. One day it just stopped powering subs. i check the fuse in the amp, and it is blown. I replace it and after i finally one that will no blow when i put it in ( about 3 fuses later) it seems like it will work. The power lights come on and everything.. only problem. Subs are not hitting. I hook up a different amp and it works... any thoughts? You can email me or just post.. thanks
Username: Islandboy808
Mililani, Hawaii US
Post Number: 341
bad amp.thats what u get for buying sony crap.
and also read this
http://pub14.ezboard.com/fcaraudiotalkfrm27.showMessage?topicID=27.topic
cmac_attack
any thoughts about the general problem?
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 3625
did u check ur inline fuse
