I would follow the manual to begin listening for a reference. If you then want to switch the pair of amps to other functions, you'll know what you had according to the manufacturer's recommendations.
craig wallace
need advise on how to run two amps. one alani 800w 4 channel. and one 1100w alani. do i connect amp to amp by bypass rca? or split from head unit and rca sepratly?
