Amp wiring help
Username: Goose5741
Okay, i'm gonna put 2 subs in my car i want to put about 300-400 watts rms to each of them, the amp that seemed the best and was in my price range was the audiobahn 8002t here are the specs:
2 - Channel
2 Ohms Stable Stereo
2 x 200 Watts RMS @ 4 Ohms Stereo
2 x 400 Watts RMS @ 2 Ohms Stereo
800 x 1 Watts RMS @ 4 Ohms Mono (Bridged)
What would be the best way to wire it??? ( i need 300 rms per sub minimum)
Username: 54danny54
Betsy layne, Kentucky.. USA duh
Post Number: 1377
ha ha...wat subs, wat voice coil configuation?
Username: Goose5741
I am not sure what subs i am getting yet (for sure) but they will be single voice coil.
Username: Sexytroca
Dallas, Texas United states
Post Number: 32
the only way u can wire that is at 2x200 watts at 4ohms, if u bridge it into one channel u will destry ur amp, i did it three times, trust me its not fun.
Username: Brynm
Prince Albert, SK Canada
Post Number: 124
if you get subs that have a voice coil config that you can hook up for 2 ohms you can run 2x400Wrms. get subs that are either single voice coil at 2 ohms or dual voice coil(dvc) 4 ohms each. just make sure you have them in separate or a divided box.
