Amp high input
Username: Puma54
I just got a 4ch amp and I only have speakers running from it, no subs (ive yet to install) if I understand right its better to run high input using speakers rather than the rca jacks. in the long run I will be using a portable device. the problem im running into is the connecter looks like this:
|W B R|
|W B R|
w=white, b=black, r=red
I have two, one on each side (left side ch 1/2 right side 3/4)
do I just y split both Bs to be used with the close by W and R and then do the same on the other side?
and if thats the case to I then crimp both high inputs to have only one left and right for portable device?
any help will.. help.
Thanks
-Puma
Username: Puma54
can any one point me in the right direction?
