Ariza 700 follow up re menu shut out -----thill1951
Username: Dotty101
Totonto, Ont Canada
Do I have to down load again the bin file I am using to run my system or am I looking for other
files to download
if so which ones
thanks
Username: Thill1951akalk
Post Number: 1351
What are U trying to say?...U only use 1 bin file at a time to program your receiver..
Grimreeper
you just need the latest bin and mabee a channel list but the channel list is really not needed cause you can blind scan channels then sort by how you want them or by sd so there setup like dn channels
