Bigdixie Unregistered guest |
Posted on Could I run 1000 watts RMS with a 110 amp alternator with a 5 farad cap and optima battery without having to upgrade the alternator? |
Silver Member Username: Cenus
Hicksville,
Ohio
Usa
Post Number: 918 Registered: Jan-05
Posted on it would be close, i would get rid of the cap and just upgrade the big 3, and then see if your lights dim any. |
New member Username: Blue_tornado_1
Woodbridge,
VA
Post Number: 10 Registered: Dec-05
Posted on Lights will dim a little anyway. u should b fine with just what u have but any more additions would probably require upgrading |
