Hooking subs up to a stock stereo system
okay, i have a 2001 ford f-150. i would like to hook a sub up in it. but i have a few questions. i dont want to buy a new stereo, is it possible to hook a sub up to the stock stereo in my truck? also, if i did that would you atually get any "thump" from the sub? or would i need to add an amp? i want to do this the cheapest way. please help me
Username: Keegan_man
Post Number: 28
yeah u would need an amp or else that sub would just be a speaker
dylanbrown
so if i hooked up an amp and a sub to my stock stereo would it work?
Username: Nemen
Trinidad & Tobago West...
Post Number: 27
Yes but youll need a LOC.
dylanbrown
this is dumb i know... but what is a LOC
Username: Graphix1
Santa Rosa Heights, Arima Trinidad & T...
Post Number: 373
1st.....Please register.
2nd...........a LOC is a Line Out Converter it takes your speaker output wires from ur head unit and turns them into RCA preouts for your amp.
