Backing up my ps2 games on to a dvd
musicmad
hi
i need to know if i copy a ps2 game on to a dvd will it play strieght away
It'll play if your ps2 console is modified. One of the ways of modifying it is to use a modchip.
Username: Squattingdog
Post Number: 13
you can also find software that will burn the corruped sectors over which is what ps uses for its copyright protection. Not that I would suggest such a thing..
Post Number: 14
oh just to clear that up you also need a dvd burner but i figured that was a given.
west
west
Username: Kyle___berg
Post Number: 10
MOO
Seal socom
if tou can make copies were do u find the soft ware I have been every where and cant find it?Can u help?
Hi i want to know the same thing a long time ago and now am a expect at ps2 back up playing.
Get a swap magic disk there easy and safe to use no mod chips
then you can play back ups
and if you have a dvd rewiter use dvd-r disk NOT DVD+R
you should have a program that comes with the dvd rewiter but if it comes with nero get clone cd
you then can make back ups and play them with out breaking you ps2
i do this all the time and a good tip when you buy or rent out a game before playing back it up
and just use the copy to keep the real game in good condision
MOD CHIPS COST A LOT AND BREAKS PS2 FASTER
SWAP MAGIC IS SAFE
Username: Budu
how can I get the swap magic?
Username: Justineve9
can i back up ps2 games with a dvd recorder
