RE Enclosure
hellos
Will it be ok to use the enclosure on re audio's website for a 12" SX. They recommend a 1.9 ft^3 enclosure tuned to 32 hertz for the SX and the one they show is 2.5 ft^3 tuned to 35 hertz. If I can use it can someone post the specs here so that I can see them. When I see them on my computer they only show the two tens and half of the ported 12". I want to see all the specs for the ported 12".
thanks
Username: Baseball1187
Columbia, SC
Post Number: 413
yup. the SX likes a little more room anyways. 2.5 will be fine
hellos
can someone please list the last four boards that I need for the SQL enclosure. I can see these:
a-36"
b-15"
c-13.5"
d-12"
e-???
f-???
g-???
h-???
Columbia, SC
Post Number: 415
hellos
I apreciate it.
thanks.
