New member Username: HedgeutTn Post Number: 7 Registered: Dec-05 | hey guys just ordered 2 dual 2-ohm 15 L7's and looking for a good amp...any suggestions? thinking about kicker 2500.1 kx |
Silver Member Username: TheelfkeeperStockbridge, GA USA Post Number: 743 Registered: Feb-05 | the KX2500.1 would work, but since you got the Dual 2 ohm versions, you'll be wired at 2 ohms or .5 ohms. that amp is rated at 2500 watts at 1 ohm. not surewhat it'll do at 2 ohms or it it'll even work at .5 ohms. if you had gotten the Dual 4 ohm version, 1 ohm would be an option. not sure what else you could use. |
eagle45 Unregistered guest | That amp should work. It is rated at 2500 watts at 2 ohms. |
Silver Member Username: Southern_bassParis, Tennessee U.S. Post Number: 338 Registered: Dec-05 | what about the orion 2500d ? |
Gold Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 3471 Registered: Jul-05 | if money is tight get this or this, same company as orion http://ikesound.com/product-product_id/2465 http://ikesound.com/product-product_id/2425 |
