i dont know if i can fit 2 kicker L5's in there but does any1 know if there is a way to fit them or are they to tall??? i want to keep the back seat in. please tell me if i can do this....
if they're just the 10's you can get a box for them and then just set the box in the seat with the subs firing up , i used to have 2 10's in an extended cab truck the way i told you
eagle45
I used to have a couple of L7's under the back seat of a 97 ford f-150. It sucked cuz I had to raise the back seat 5". The subs were firing up and it was really loud but then I decided to take them out because people that got in my truck were complaining that the seat was too high.
