John l. Cashville Unregistered guest | Box Dimensions Calculator http://www.carstereo.com/help/Articles.cfm?id=45 |
Gold Member Username: RovinTrinidad & T... Post Number: 4072 Registered: Jul-05 | like this - u enter 2 sides that u want ur box 2 be , thickness of mdf u are using (usually 3/4) & it gives u what the 3rd dimention should be = to . that calculator gives u external dimentions as it says so that just makes life super easy .......... |
