Bad Box Design for w6's
Username: Qcsfinest
Post Number: 126
a while ago someone gave me this design for my 12w6v2's but after really paying attention to it, it cant be right.
4.58ft^3
tuning freq. 32hz
port dim. 3" x 14.5"
port length 23.5"
W 32" x D 19.75" x H 16"
Port: H 14.5" x W 3" x L 23.5"
(2) front/back: 32" x 16"
(2) top/bottom: 32" x 18.25"
(2) sides: 18.25" x 14.5"
(1) port #1: 14.5" x 15.25"
(1) port #2: 14.5" x 3.75"
with the port being 3" wide i dont see how this could work. on the jl website the prowedge box (which is sealed) for two 12"w6v2s is 32"
Username: Qcsfinest
Post Number: 127
anyone have the specs to build a ported box for two 12 w6v2s?
Username: Qcsfinest
Post Number: 128
bump!!!!
Username: Lexuscoop
Post Number: 482
theres a site that you can put in dementions you want for your subs, and make it equal the cube feet you want, but i can't find it
Username: Tjmutlow
Post Number: 602
look at this , comes from a box manufacture I deal with. J. L. AUDIO
Vented J L Audio Enclosures - Slotted Ports - Works With W-O, W-3, and W-6 Drivers - 3/4" MDF
Model # Total Openings port port fb / f3 W H TD
Cu.Ft. Available area depth
VJL130 1.32 1 - 10" 12 sq" 22 37 / 33 11 1/4 13 21 7/8
VJL180 1.84 1 - 12" 14 sq" 19 35 / 28 13 15 21 7/8
Note: Net Cubic Feet Less Port Displacement ONLY!
New for 05, enclosures for the W1V2 and the W7's. Our W7 enclosures have 1.5" faceplate
1V210 1.51 1 - 10" 13 sq" 17 39 / 33 23 7/8 12 1/8 12 1/2
1V210D 3.18 2 - 10" 13 sq" x 2 23 39 / 33 30 3/16 13 1/4 18 1/4
1V212 2.12 1 - 12" 24 sq" 23 38 / 31 24 1/8 13 1/4 15 7/8
1V212D 5.63 2 - 12" 19 sq" x 2 31 37 / 30 34 3/4 15 17 1/4
1V213 3.24 1 - 13" 32 sq" 26 35 / 29 25 1/2 15 5/8 17 7/8
1V213D 5.72 2 - 13" 46 sq" 17 35 / 29 35 17 20 1/4
8W7D 2.40 2 - 8"
10W7S 2.17 1 - 10" 15 sq" 13 38 / 30 23 3/4 13 1/4 16 5/8
12W7S 2.11 1 - 12" 24 sq" 29 37 / 33 24 1/8 13 1/4 15 7/8
12W7D 1.90 2 - 12" 24 sq" x 2 28 40 / 36 34 3/4 15 17 1/4
13W7S 3.24 1 - 13" 32 sq" 26 36 / 29 25 1/2 15 5/8 17 7/8
