RCA Pro 8 camcorder
melody621
I bought the RCA Pro 8 camcorder about 1989, so I know it's old. However, for some reason I am unable to get it to record or even playback 8mm tapes I made years ago. Is it worth getting fixed? Where could I send it to get repaired? Or should I just forget it?
I have an RCA Pro 8 without the accessories-it still works well. Are you interested in purchasing as it may be less than getting yours fixed
ifinstad@gmail.com
We have a old RCA pro 8 but we don't have a battery for it. Will someone tell us what battery it takes?
Thank you
Trent Regan
I'm trying to find out myself... I've got a working battery, AC adapter and plenty of tapes. But for some reason, I can't get it to records or playback either. However, I have been able to playback old tapes that I recorded years ago. Let me know what you find out.
You can go to Staples online and use the battery wizard to find a match.
bigoster
The RCA pro 8 takes a AV8M3W NiCad (6V) or a compatible NiMH (6V) camcorder battery. They run $20-$30.
