Hifonics amp???
Username: Johnleabu
Post Number: 29
i was gonna buy this amp caz i love how it looks and it says it does 1500 rms@ 1 ohm but someone told me hifonics only puts out about 70% of ther rms i want at least 600 rms will this amp but fine http://ikesound.com/product-product_id/2885 caz if not i will just buy the re audio 12.1 amp but its like 120 dollars more tell me if that will make my 2 12" se's loud? the hifonics amp
Username: Johnleabu
Post Number: 30
i meant i want at least 600 rms to each sub**
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 3447
how much are u willing 2 spend on an amp, there are tons of amps that could fit ur needs
Username: Johnleabu
Post Number: 31
about 200i either want hifonics or power acoustik if not them then im goin with re but its alot more i like that hifonics wil it be fine?
Post Number: 3452
dont even consider the pa, since u are on a budget get the hifonics amp.
Username: Johnleabu
Post Number: 32
hey chaunsey get on aim please??
Username: Johnleabu
Post Number: 33
will the 1500 work fine? i mean if it will be pretty loud it will e fine with me until i can get a different amp i think i will order the hifonics one tho but get on aim so we can talk
Username: Islandboy808
Mililani, Hawaii US
Post Number: 314
itll get loud
Mililani, Hawaii US
Post Number: 316
btw check out this amp
http://ikesound.com/product-product_id/2167
it pushes out its rated power and is CEA complient
Username: Johnleabu
Post Number: 34
yeah i dont want any reburbished stuff
