biverland Unregistered guest | The fix is on : dss.tester.com you have to registes to get....its free ... |
Iqbhu Unregistered guest | umm yah, but CNN channel doesnt work? any solutions?? |
New member Username: AshkitPost Number: 1 Registered: Dec-05 | I have a X-05BL_051213_136eubx_au_api.bin file for autoroll in fortec lifetime ultra. Will this file work for autoroll. Also does any body know what file I need for BEV. Any help is highly appreciated. Thanks |
Good Info Unregistered guest | Yes. Fox News!! |
Bronze Member Username: Tomuch4youNew yorkUsa Post Number: 51 Registered: Dec-05 | I just put the new pin file in my lifetime ultra and I go CNN channel back and a few HBO channels also. I used the FTA ultra 282-t2-12 h-clock.api everything is working fine. I want to thank you all that are help to get free tv working. Bye |
New member Username: WassupmanePost Number: 4 Registered: Nov-05 | what is the code you put in the code box when trying to put in keys. Please help me with this! |
Bronze Member Username: Tomuch4youNew yorkUsa Post Number: 52 Registered: Dec-05 | My friend if you have the lifetime ultra the keys are in the pin file. Just read my post and put the file in your receiver. You should be watching tv in a very short time. code for key box...1010 or 1668 this won't help you if you got my box! |
New member Username: KingevertonKingston jamaica Post Number: 3 Registered: Apr-05 | what must i do to get HBO NBA SHOWTIME pleASE CAN SOMEONE HELP ME, IHAVE A PANSAT 2500A THANKS IN ADVANCE GUYS |
New member Username: CdogPost Number: 1 Registered: Dec-05 | how do i get to the keys so i can change them in a cooltec |
New member Username: Jasonswife19Post Number: 5 Registered: Jun-05 | Can't get access to that site. Comes up page not found. |
biverland Unregistered guest | ... olso you can get this file.. at |
biverland Unregistered guest | olso on this ....its free ..but you have to register ...its simple ok ...have a nice day.. for the good of FTA |
Any Mouse Unregistered guest | @ Lisa loose the dot between dss and tester ie. dsstester |
biverland Unregistered guest | [link removed] |
biverland Unregistered guest | are evrybady up ... ??? Are the fix fom 20dec ... 100% ok for evrybady .. Fortec Life Ultra.... |
mtl Unregistered guest | Hi biverland, does not work for me. I lost Tv a few days ago no coding seems to work. What i can do, where to find the code to enter and get my tv back. feel free to email me at vicwin_2@hotmail.com |
New member Username: HighlyaccuratePost Number: 1 Registered: Dec-05 | Hello Guys Any body can help me, for new keys about fortec ultra |
George438 Unregistered guest | Biverland, Here, the fix from 20 dec for Fortec is working... except tp2 on 119 (no signal quality at all). Everything else seems ok. I wonder why that tp is out... Or does DN moved everything that was on that tp? Mmm... A powerscan gave nothing... |
