Can't get sound to come on home theater speakers from tv
simbacsi
Just got a Insignia 1000 watt from Best Buy. I hooked everything up but can't get home theater speakers to play from Tv
Username: Paul98
Post Number: 88
How is your tv hooked up to your receiver? How is the rest of the equipment hooked up?
simbacsi
I have the receiver hooked up to the tv with a s video cable. I want to hook the tv and playstation 2 up so I can hear everything on the ht speakers.I followed the instructions they gave me but it was tough to follow with the black and white illustrations.
The only other thing I have hooked up are the RCA cables that came with the system exactly how they have illustrated on the diagram.
I can't figure out how to run the cable line from my tv into the home theater receiver. There is no place to put it.
Styki
Run cables from your audio/video out on your TV (not composite or s-vid) to the a/v in 1 or a/v 2 jacks on the receiver. Then turn on your TV and choose av 1 or av 2 on the (DVD) receiver depending on where you have them hooked up
