L7 louder than Sx?
elmac
Comparing the 12" L7 properly powered in a ported enclosure with a 12" Sx again properly powered and in a ported enclosure. Which one of the two would produce more spl? I have an L7 but it sounds like crap. I want a better sounding sub but with a little more spl than an L7.
Username: Greeney
Grove, MN US
Post Number: 144
the SX has 1000RMS and the L7 has 750RMS so its pretty simple answer, the SX will have better SQ the n the L7 cause ive had both subs before
Username: Rovin
Trinidad & T...
Post Number: 4007
agreed ^ ^ ^...........
Username: Southern_bass
Jacksonville, Florida U.S.
Post Number: 288
sx anyday
Username: Sploosh56
Ohio
Post Number: 999
the power has nothing to do with how well a sub will sound and how loud it gets really. It's the design and build quality. That is why the SX will win. If everything was all about power handling then audiobahn would be amazing! Not
Username: Araknid
BOCA , FL U.S.
Post Number: 1491
Also remember just because a sub has a high power rating doesnt mean its always gonna use it effectively, some subs are just inefficient and power hungry.
