Archive through December 21, 2005
Examine this site
www.extrememicro.com
Username: Thill1951akalk
Post Number: 870
Clone-safe Bin
Credits to "mile" for cleaning this file,
This is a Dishnet file, NOT Bev/bell
Tested and good on Pansat2500a, Fortec Ultra, PanTec
you can discuss this file here -->> http://www.gat-s.biz/forum/showthread.php?t=6670
PLEASE USE ALL FILES
AT YOUR OWN RISK...
WE ARE NOT RESPONSIBLE
FOR YOUR ACTIONS!
here's the direct link to the file...register first!
http://www.gat-s.biz/forum/showthread.php?t=6669
Post Number: 871
This is a working Bev file for the Pansat 2500 ...released today!...its located at www.dsscentral.n*et ..Pansat files area
X-85BL_051125_260_api(N).zip
I have a working Pansat 2500A. I am about to buy another 2700A, since they no longer make 2500A anymore. I have the following questions.. and would appreciate if an experienced person can help me with the decision.
1. Is 2700A a good choice? or should i go for 3500A? The difference is like $20.i.e $189 vs. $169.
2. I know how to program 2500A. ie
- file location, new flash followed by latest bin
- i dont think 2500A file will work on 2700a? will it? if not where can i get the procedure and latest bin for 2700a?
Thanks for your help.
Post Number: 874
They all use different bins...all are good....[link removed] is the best Pansat site for files etc..not much diff between 2700- 3500 ...I would go with either or the viewsat2000 platinum..
Thanks thill1951..appreciate it..
Hi thill1951..
Thanks for directing me to www.future-fta .com. I agree its a great site and very easy to find stuff. I just downloaded 3 files.
1. 2700.zip - contains factor bin for 2700
2. GTRom loader - similar to 2500a BL downloader
3. X-87BL_051124_123_api(N)_newKeyp.zip - latest bin.
My question is that all I needed? Is the procedure same as 2500a. i.e
- start with factory bin
- then new bin
Is downloading channel list necessary? I am missing any other steps?
Thanks !!!
Username: H3lt3r_sk3lt3r
Post Number: 717
@Anonymous
Everything is identical to 2500 only as Thill already pointed out bins and loader are different.
Great !!! thanks both for the help
those who benefit
what have you got to lose?
you are to childish for me.
Whining fool
Just ask the know it all
stop acting like my kid
I can tell your kid is a whining sissy
So you don't want to pick a fight,bull.A lot of people are benefitting from this forum.Mine your own bussiness ,no one needs to hear about your pathetic lack of attention.Back off.we don't need your stupidness.We appreciate the information we are getting.
ok whatever dude
Username: Chem
do not be sad or feeln bad. Eat beans, it is good for your heart and make you tart.
My pansat 2700A works fine at one location but does not at the 2nd location. Both locations had professionally installed dishes and LNBs by Dish networks. So I don't think there is any HW issue. I tried deleting all channels installed from location 1 and attempted a fresh blind scan at location 2, but it did not find any TPs. The Quality and levels are like 29% and 0% consistenly on all Echo 3,7, 8.6, nimiq.etc.. I have no clue what's wrong. The BIN is fine, since it works at Location 1. Any hints are appreciated.
Thanks
Post Number: 770
How sure are you that both locations have an identical setup? ie same lnb's, same switch setup.
The switches may be different, but both sites had two dishes. 1 for local US and 2. for international channels and both were installed by Dish Networks. Physcially the two switches look different, but would that cause an issue? since both switches were used for similar programming?
Post Number: 772
Here's what might cause the problem, while you have the same setup, the actual diseq settings on the box itself might not be the same for both locations.
Here's an example with dish500, using a diseq switch.
Physical switch setup:
110 lnb connection going into input 1 on the switch.
119 lnb going into input 2.
On the receiver (Installation>Antenna Setup>choose sat):
110 - lnb type: standard, lo freq: 11250, diseq: #1, 22khz: OFF.
119 - lnb type: standard, lo freq: 11250, diseq: #2, 22khz: ON.
cold up north
folks,
i have a fortec star ultra. everything works fine but i would like to know how to get rid of the duplicate channels and how do i get showtime and the disney channels.
your help would be most appricated.
cold up north
folks,
COLD COLD
folks,
i cannot get any HBO also and i scanned the tp that is provided to get the HBO but when i go to the channel i only get abc and local channed. i am in Canada
cold men
guys can you help me
everythings works find for DISH Network on EchoStar 7 at 119.0°W bu my TP 6 has 85 level and no Quality and i need this TP to get HBO and showtime. please help.
Username: Maple_leaf
Post Number: 956
No szot or thill1951 or what you call your self now go back to your other site. No answers here !!!!
Ps You just can't stay away huh. I knew you couldn't.
cold meen
hey maple leaf can you help me
smithy jones
cold men ,, there are many channel list i found here [link removed]
moeway
pansat 2500a 119 all channels no problems.110 all channels work but receiver shut off wait 2 mins turn it back on work good for another few minutes any ideas? signal for 119 and 110 both in 90s. thanks in advance
Ready 119
Can any one tell me how i can get sat 119 i have 110 thanks for any help
Ultra x
Does anybody know how to Restore Dead Fortec Lifetime system if yes please tell me I have a fortec ultra THANK YOU
colddd
can someone help my fortec has no power on the front. after downloaded a fle.
can some on please help.
Post Number: 989
Yes szot get a good reciver.
Post Number: 990
Yes szot or thill get a good receiver.
artemis_bliss
What is the new satllite key? Hello? is anyone listening?
Iam eating cheese and I need the New Keys
pansat keys pleeeeeaaassseee!!!
Deputy Dog
Bow wow wow yippee yo yippee yay! Who got the binz pleeze post away!
anybody have any new keys please can u post them on the internet so i can get my wife and kids off my back. thanks
Username: Whatzzzuppp
Montreal, Quebec Canada
Post Number: 11
anybody could help 4 the fortecstar keys
i need a real help
please somebody for the fortecstar
thnxxxxxxxxxxxxxxxxxxxx in advance
Grimreeper
cyberworld has bin with new key
JoonBoy
Where/What is cyberworld?
omar786k
go to this site [link removed]
to download the new bins
JoonBoy
Has anyone checked the new bin out? Any good?
bosanac
does anobody know how to get back the ex yu chanells on t5/ku,pink,bn,bk?thanks in advance.
dish_newbie
Link posted by omar is not working
Grimreeper
put .com on the end of cyberworld find the downloads and get the file you need
Username: Sat
Y, Y N
Post Number: 18
YOU NEED TO GET NEW FILE
can anyone help i have a pansat 2500 with pantec clone.how do i get the new keys to work
I am having a problem with the latest bin 264. I can't get 110 channels. I get all of 119.
I never had this problem with prior bins.
Can anyone help?
i downloaded this file and it killed my cloned pansat 2500 Pansat2500-X-85BL_051206PM_264_au(N)-AUTO my receiver will not turn on anymore. Can anyone help
whatloaders # i need for pansat 2500; 2700; and 3500 thank you very much for you help
troy2388
@ bosanac
you need a 30 inch dish to get t5 ku channel
@ anonymous
with the dead clone pansat2500, you need to jtag.
eral
where can i get new bin file for FTA centarl is what i had they don"t have new one yat thanks
anonymouscat
Anyone the keys please
bosanac
can someone tell me how to get ex yu chanells back on t5/ku?i had all chanells than one day those[pink,bn,bk]would say scrambled chanell,i heard they went to nagra 2.if somebody knows anything about this please post it here.all other chanells stil working except pink,bn,bk.any help would be appreciated.thanks
FOR SALE
I heared people were buying the bins for $50.00 for BN PINK BK
any mouse
fortec star ultra lifetime up & running receiving all channels using Ultra_282t_new_keys_dec_06_05 bin
NOT FOR SALE
FOR SALE
CAN YOU SELL THEM FOR $50 ?
Username: The_real_lk
KEY WEST, FLORIDA US
@ U bunch of c_o_c_ks.....STOP fvcking up my
good, good name.... Iam the real LK and Iam
sick of all the kids on this sight....If U don't
stop it....Iam going to "LEAVE and CRY" to my
moma....I did have a moma...She and me in the
bathroom at the bus station...She told me I was
a b_a-s_t-a_r_d and that Kne-grow could be my
dad.......But she ain't shore because she is the
O from the shore or.....(He-Ha-He-Ha)
She also told me that she had s*ex with my chimp
(maybe thats why I like bananas alot....And Iam
not talking about the eating kind....Its the
s_u_c_king and fvcking kind I like....So please
STOP making my name trash...It took me many years
to make a new name....Your friend LK....Bye
Post Number: 954
This site is like the TITANIC...its sinking real fast with NO hope of salvage...see ya..
Username: Munir2k6
hello . I have a serious problem with my reciver and i am wondering if you can me . I have a lifetime ultra. Three of my channels 1 is eritrean tv the other romanian 1 and romanaian 2 have gave me a signal that says scramble channels. The question what can i do to get back these channels??? Thank very much for your help.
romanian dude
i lost the romanain channels!! Can someone please help me???Desperate!!!!
cool site
www dot undergroundforever dot com
help if you can plz
Can someone help me?
I put the new bin into the box (works fine)
but it only works with satellite echo7(119) all the channels from echo6.8(110) do not work. can someone tell me why?
Post Number: 957
To get the 110 and 119..
Open a working channel list with Channel Master. Go to list of Satellites on the left and right click on "Satellites" and then on "Add Satellite". Enter a dummy name. Then look down a few lines and you will find a radiogroup marked "State". Make sure "Select" is selected. Close this dialog by clicking on "OK".
Now go back to the list of Satellites and right click again and this time "Reorder Satellites by"/"Degree". This should move the dummy sat you just created to the top of the list.
Save the list and then write the list to the STB in the usual manner!
Username: Sameh71
can anyone tell me why i can"t get desney channel in my pansat 2500a clone
When using Fortecstar STB updater ver 3.31 (from fortecstar.ca)I do not know what to select to update my bin file to get all my channnels back.
I had the channels until dec.06-2005
I am choosing 1. Flash rom file or 2. Channel Data file 3. Boot file?
Do I need to choose something for STB model?
Should I change serial port if it keeps failing?
Post Number: 1024
Hey thill or lk or what ever you got that right.
Enter a dummy name.
Does any one please know what is the latest Bin for fortec and a web site that has it..Thanks
I HAVE A 2500A PANSAT RECEIVER WITH NAGRAVISION. IT STOPPED WORKING ABOUT A WEEK AGO AND ALL OF THE CHANNELS ARE SCRAMBLED. HOW DO I FIX THIS? DOES ANYONE HAVE THE CODES TO FIX IT? IF SO PLEASE POST THEM OR E-MAIL THEM TO ME AT stairway_to_heaven_519@hotmail.com
Username: Ricos
hi i have a fortec ultra receiver. Now i have tried all the bins and it says bad channel. I noticed that under the code section for changing the keys it says key function off.
How do i turn it the keyfuntion on. Is there any way. I have tried the remote it does not work etc. Is there any bin file which will work without remote control. Neither is there an option forto find nagravison 2. etc., Please help me i am desperate without tv.
turn on keycode
just enter 4 zeros to turn the keycode function on.
Username: Leejay
Hi All
I have a fortec star 7 button digital satelite reciever and i accidentally uploaded the wrong software to it from the fortec star website. I uploaded the fortec star lifetime software to it. I have got the proper fortec star 7 button software for it and i have tried to upload it and it sucessfully uploads but when i switch the reciever off and on again it still displays jumbled characters on the front screen and says and does nothing when plugged into the TV. I have tried to upload new boot files to it using the ALT7Bar downloading tool v1.31 but as soon as you select the file and tell the software that it is a boot file it says "File type Dismatched". I am using boot_Al7bar%20FTA(7)_ver60_040519.bin to try and update it. I have read forum after forum till the cows came home and i think my problem may be unique. Is there any other updating software that could upload the boot file, that might work?? Or any other suggestions??? I have included an image of the front panel when the unit is powered
Any Help would be appriciated
Regards
Leejay
Username: Konfused
Post Number: 13
can somebody please tell me
1. if I need a rs 232 straight cable to upload new bin fiels from my xp computer to Fortec Life Time Ultra receiver?
2. If yes, from where in Toronto/GTA can I buy this cable? Is there any other similar cable more easily available
thanks to anyone who replies
you can buy your cable from factory direct. i believe that you need a db9 straight thru cable female to female on both ends etc for fortec receivers. Dont use apansat cable it wont work becuse its is a cross over cable etc
Username: Ricos
Post Number: 7
Does anyone have the pansat 2700a original auto roll file that is safe and actually been tested and deemed good.
There is the 132 bin that is killing pansat clone receivers etc.
Can soembody like thrill or sopmebody with knowledge please reply. My receiver is now busted.
It does not power on after downloading the 132 autoroll file.
Please help etc
johnibraham
Can someone help me with new bin file and keys for digiwav 7000 (dishnetwork) please
Username: Donkamyo
does any body can help me my fortecultra life after flash ,does'intwork no light nothing is dead.can you help me please.what can i do
Username: Leejay
I have been using a modem cable, is this a problem??
Username: Musa270
Can anybody tell me what program is used to find channels and how to use it because i am a newbee in this receiver stuff my email i wwww.bosnasmostwanted@insightbb.com
hey leejay i dont know what modem cable you have been using. Just get a straight thu cable db9 female to female and you will be ok.
Username: Leejay
Thanks anon, i just wasnt sure, still cant get the stupid thing to work
Regards
Username: Konfused
Post Number: 14
thanks anon
austin 316
I think I got the new bin (282)loaded but I,m still not getting any good channels , was told something bout parental control ,can someone give a helping hand ,please
I HAVE A 2500A PANSAT RECEIVER WITH NAGRAVISION. IT STOPPED WORKING ABOUT A WEEK AGO AND ALL OF THE CHANNELS ARE SCRAMBLED. HOW DO I FIX THIS? DOES ANYONE HAVE THE CODES TO FIX IT? IF SO PLEASE POST THEM OR E-MAIL THEM TO ME AT kodeedotcom@hotpop.com
Username: Juliet2972
I have a fortec lifetime Ultra and in Africa using PAS7/10 at 68.5 E. I can only watch SABC 1-3 & Etv. Can anyone help , need to watch Mnet, Channel O etc. How do I go about it. Help !!!!
eye
Ok, Fortec Fans........
Heres some keys that gives all
01: 8A C4 96 93 EC 79 9D 57
00: 01 C5 FB 21 37 B6 C0 5E
ppv, adl, passes for sports...works for Ultra
It works!! Dishnet :Nkeys
FYI: unless you have a old laptop or desktop with XP pack1 or older windows you can't connect with a USB port and rs232. Beleive me I tried with my Sony xp..... and with other connectors...
Username: Search908
Tonasket, Wa Usa
help Just got a pansat 3500s What do I need to do to make it work, and how do I do it?
RIZZO!!
Buzz off puss head!
Username: Tomuch4you
New yorkUsa
Post Number: 14
Another thread hijacked by thill 1961 and his kids. They service this sight nothing but valgat remarks towards others.
Can i use the X-85BL_050926_256_api(N) bin file for Pansat 3500 or the viewsat2000 platinum..
Username: Zamzoom
PANSAT2700A IS DOWN .TUESDAY DEC 20.2005. ANY NEW KEYS ARROUND?THANKS
eral
down agian any new binfiles for fta ultra thanks
Post Number: 1124
Yes TODAY, with the latest keys..
www.dsstester.c*om (its all FREE)..also remove the * in the .c*om in the links
dec 20th key change, load this file
here is the file...FORTEC LIFETIME ULTRA ONLY
Al7bar FTA Ultra_050926_282t2_12H_clock_api(NTSC) dec 20 new keys.zip (386.1 KB, 611 views)
any one kknow where i can get the bin file for a fortec star ultra?
the Al7 bar FTA Ultra_050926_28212_12H_clock_api(NTSC) dec 20 new keys.zip file would work on what the 110 or the 119?
biverland
i posted the file on ...Newbies.... FSFTA
Korian F2A.....Curious Contraptions...its ok
The file i instal on Fortec Lifetime Ultra work
super.......open 110....61.5....IA5 ...oll bac
so its 100% ok
new helper
http://forums.dsstester.c*om/vbb/showthread.php?t=44717
i uploaded Al7 bar FTA Ultra_050926_28212_12H_clock_api(NTSC) dec 20 new keys.zip file to my reciever and when i turn my reciever off then turn it back on the on wouldn't show like it shound. The only thing the light is doing is moving back and forth...can you help me?
Mr Bean
A nony mouse
Al7 dar FTA Ultra_050926_28212_12H_clock_api(NTSC) dec 20 new keys.zip ???
i hope you mean
Al7 bar FTA Ultra_050926_282t2_12H_clock_api(NTSC) dec 20 new keys.zip
Info that I have gathered
The file to use is..
Al7bar FTA Ultra_050926_282t3_12H_clock_api(NTSC)
this will allow you to manually enter the keys in the future
How to change the NAGRA2 Key codes
(for Fortec Lifetime Ultra only)
1- Press Menu button on your remote control
2- Press right arrow key 2 times Channel Edit
3- Press down arrow key button 2 times, press OK (Code) enter 1010
4- Press the down arrow key to Set Default Key, click OK
5- Press the down arrow key to Nagravision click OK
6- On your top left you should see Nagravision-1...if not, then you've got the wrong BIN version.
7- Press right arrow key until you see Dish Network on top
8- Press the down arrow key once to Key Number
9- Press right arrow key 2 times the from Key Number 00 - 01 - 00
( Now take notice that on your top left you should see Nagravision-2 now )
10- Then press DOWN button key to change the keys manually on Key Number 00
11- Enter new Keycode, do the same procedure to enter the the keys on Key Number 01
Mr. Bean
sorry that 284t3
Mr. Bean
correction
step 5
Press the up arrow key to Nagravision click OK
Be sure to turn the Keycode ON before you exit.
password 1668
