New member Username: BcmPost Number: 2 Registered: Dec-05 | I am just starting to build my first home theater system and have purchased a pioneer vsx-515-k reciever. Was this a good choice? and does anyone have suggestions on good speakers/subwoofer? I would like to keep under $1000 if I can. I am new to this and any information I would greatly appreciate. |
Gold Member Username: Project6Post Number: 4531 Registered: Dec-03 | Whether or not it is a good choice really is up to you. You are using it and you will have to live with it. So if you like...that is all that matters. For that budget, I suggest you look at Ascend Acoustics. Wonderful set of speakers and great value. http://www.ascendacoustics.com/ |
