Bronze Member Username: Redbone15367Mo U.S.A. Post Number: 25 Registered: Sep-05 | does it make any real diff on sq or spl having magnets in or out? thanks |
Silver Member Username: Alex_fLawrenceburg, Ky Us Post Number: 262 Registered: Nov-05 | if you make a box for the sub to have the magnet in, and then you turn it out, there will be more area in the box. i put 1 of my eclipses with the magnet out and it sounded like crap. |
Gold Member Username: Mikechec9Http://www.cardomain.c... Post Number: 1915 Registered: May-05 | no. just box volume (besides any mechanical noise introduced by the motor). |
Bronze Member Username: Redbone15367Mo U.S.A. Post Number: 27 Registered: Sep-05 | ok that help's me. trying to get an re/ mt 15, and would like to show it off. going to run 2 250r hcca's to it. dual .7 ohm |
Silver Member Username: GeekbikePost Number: 406 Registered: Dec-04 | It's an MT. If you know what to do with it, it will impress everyone. |
Gold Member Username: RovinTrinidad & T... Post Number: 3976 Registered: Jul-05 | here's ur answer http://wickedcases.com/caraudio/inverted.html |
Bronze Member Username: Redbone15367Mo U.S.A. Post Number: 28 Registered: Sep-05 | Thanks for the link, anserd it perfectly. |
