How to hook up 2 amps?
Username: Banginscrew
Post Number: 14
this might sound dumb but im not sure how you hook up 2 amps to 1 car or jsut the battery itself does anyhting need to be done or can u just overlap teh amp wires to teh battery???
Username: Tjmutlow
Post Number: 493
use a distribution block main wire in, then splits off to the other amp.
Username: Adireaudio
Lynwood, Washington USA
Actually, use a bigger wire like 2 gauge power wire into a distribution block and run 2 ends of 4 gauge to your amp. same thing with the grounds, wouldn't hurt to have 2 seperate grounds though.
