Necessary
Username: Lexuscoop
Post Number: 400
would you guys recomend a capacitor for your system or is it a wast, or does it depend on how many watts your running?
Username: Lexuscoop
Post Number: 401
and the same with cross overs, do you need them or not matter
http://www.bcae1.com/
Username: Lexuscoop
Post Number: 402
thank you
Username: Solacedagony
New Jersey US
Post Number: 709
First, learn what each piece does.
Here's a link on charging systems (including capacitors):
http://wickedcases.com/caraudio/charging.html
There should be info on crossovers on bcae.
Username: Jonathan_f
GA USA
Post Number: 5165
Capacitors: No.
Crossovers: They're essential.
New Jersey US
Post Number: 715
Yea sorry, I would have detailed more on those myself, but I'm at work when I make these posts, so I'm trying to cover helping out more people, so my posts tend to get less detailed from lack of time :-(
New Jersey US
Post Number: 716
Username: Lexuscoop
Post Number: 404
ok so like Capacitors are pointless or pointless untill you get to a certain amout of wattage? how much are cross-overs?
Username: Fandim
Reno, Nevada United State...
Post Number: 537
Capacitors in most cases make no audible difference in your sound, and if anything, put your stress on your electrical system.
Username: Lexuscoop
Post Number: 407
yeah, because my friends lights dimmed to the point where they were almost off, then he installed a capasitor and they just barley dim now... so they are just for the electrical benefit, not the soung benefit. and the cross-overs are for the sound... correct?
Username: Lexuscoop
Post Number: 408
sound*
Username: Mikechec9
Http://www.cardomain.c...
Post Number: 1916
"yeah, because my friends lights dimmed to the point where they were almost off, then he installed a capasitor and they just barley dim now... so they are just for the electrical benefit, not the soung benefit. and the cross-overs are for the sound... correct?"
his alternaor is now feeding the cap and the battery. it will soon die. the lack of "symptoms" is similar to steroids for athletes in sports. they play hard for awhile until their bodies break down.
