Whas d deal with fuse ratings on amps
Username: Graphix1
Santa Rosa Heights, Arima Trinidad & T...
Post Number: 299
Today i saw a 1200w amp with 2 20A fuses and if i remember corectly watts are amps x volts soo....12v x 40A =480 now how the fck can that amp produce 1200 watts cleanly!!.....or is the another part of the equation missing
Username: Lexuscoop
Post Number: 406
isn't it just a number, like sony say 1200 but only give out like 200 watts...
Username: Graphix1
Post Number: 304
bump
Username: Tjmutlow
Post Number: 539
it determines the amount of amps that amp draws,
Username: Alex_f
Lawrenceburg, Ky Us
Post Number: 272
my friend thought his cousins sony amp put out 1000 watts just because it said 1000 watts. i toldhim there is no way it could, but he wouldnt listen.then i found this sony amp online that said 1000 watts but only put out 165x2. i printed the pic and he said that was the amp his cousin had.i really proved him wrong
Username: N2audio
Lawrence, Ks USA
Post Number: 65
welcome to the world of budget amps.
Actually - compared to some of the REALLY cheap ones a 1000w max rating with 40A fuse isn't all that ridiculous. It might sniff 1000w on a peak.
Username: N2audio
Lawrence, Ks USA
Post Number: 66
plus, just because there's a 40A fuse on it doesn't mean it can't draw 50 or 60A for a fraction of a second. It can take as much as a second for a fuse to blow at double its rated current.
Username: Graphix1
Post Number: 305
so in most cases the fuse rating determines the output approximately
Username: Baseball1187
Columbia, SC
Post Number: 378
yup, like you can look at the fuses on Hifonics amps and see they cannot put out their rated power
Username: N2audio
Lawrence, Ks USA
Post Number: 74
it's a rough estimate at best. Like I said, fuses don't blow the instant they see rated current. An amp with 40A fuses could easily draw 60-70A for music peaks.
The old Lanzar Vibe 1200D for example had 3x30A fuses but would do over 1200w on the test bench.
