New member Username: AdasBradenton, Florida Post Number: 1 Registered: Dec-05 | Hey I need some advice, like everyone. I've been looking to get a pair of subs for chirstmas, and looking around and researching seems that having 2 13w6's with a 1000w a/b plate amp would be a great system for sq and loudness. Now, putting 2 together in the JL recommended ported box(1.875ft), would that be good? Or would the Sealed be better(1.625ft) for my application. I am leaning towards ported since this will be more for rap/rock music and movies. Also, is the JL recommended box the best for the sub, or would anyone have any other suggestions. And last but not least, How much louder will will these together get over a single Lethal Injection 12"? Thanks |
Silver Member Username: Alex_fLawrenceburg, Ky Us Post Number: 217 Registered: Nov-05 | a crown amp would sound really nice. they would be better than a plate amp. loook for them at www.partsexpress.com or ebay. |
New member Username: LicidOhio USA Post Number: 4 Registered: Dec-05 | If price is not an issue..... http://www.audioholics.com/cedia/cedia2004/JLAudioGothamFathomsub.php |
New member Username: AdasBradenton, Florida Post Number: 2 Registered: Dec-05 | Thnaks guys, but err I already have the amp, and it's actually really nice. The Fathoms are awesome, but price is kind of an issue, I don't want to go over about $1k for the woofers. That's not really my question though...would the 13W6's be good enough sq for a home application, or are some other woofers that you recommend? I need to put them into 1000w @ 4 ohms Thanks |
New member Username: AdasBradenton, Florida Post Number: 3 Registered: Dec-05 | Any help would be appreciated |
Gold Member Username: James1115Wilton, Ct Post Number: 4407 Registered: Dec-04 | I would use either a avalanche or a ID max, you cant get 4 ohms with a w7 |
Gold Member Username: James1115Wilton, Ct Post Number: 4408 Registered: Dec-04 | I would use either a avalanche or a ID max, you cant get 4 ohms with a w7 |
Silver Member Username: TdbdadrummerPost Number: 763 Registered: Aug-05 | He's using the W6 though...For better SQ eh? Wharfedale, Paradigm, and Klipsch are some of the really high end home audio providers. They would be what JL/RE to car audio in equivalency, but for home audio. |
Silver Member Username: TdbdadrummerPost Number: 764 Registered: Aug-05 | http://www.paradigm.com/Website/SiteReferenceProduct/RModels/SeismicSeries/Seism icSpecs.html Sorry guys, but just one of those puts any JL Fathom sub to shame. Just the way it's gotta be I guess... |
Gold Member Username: Mikechec9Http://www.cardomain.c... Post Number: 1884 Registered: May-05 | REL Stampede 660.00 http://www.rel.net/index2.htm B&W PV1 1141.00 http://www.bwspeakers.com/index.cfm/fuseaction/products.models/Label/Model%20PV1 |
Gold Member Username: Mikechec9Http://www.cardomain.c... Post Number: 1885 Registered: May-05 | and then, of course, if you can get them to sell you one: http://ultimateavmag.com/features/704way/index1.html |
Silver Member Username: TdbdadrummerPost Number: 766 Registered: Aug-05 | Mike's choices look nice as well. Mine are a tad out of the $1K range most likely anyways. They're for, well, the well endowed, cash-wise. |
New member Username: AdasBradenton, Florida Post Number: 5 Registered: Dec-05 | Great recommendations guys, But I was more asking about car subs to put in my room, already have a good HT sub, I'm looking for the better output, not for HT but like car audio subs in my room :-D I already have the amp, so I was asking what 2 12-13.5" woofers would be good for nice output and sound quality that are 500w each, 1000w together into 4ohms. I don't really need any recommendations on pre-built HT subs since I already have the amp and wanna build my own box In other simple terms, are there better woofers then the 13W6's for what I'm looking for? |
New member Username: AdasBradenton, Florida Post Number: 7 Registered: Dec-05 | Ehh...ok last question... Having 2 13w6's, is it better to make a dual ported box sharing the same chanber, or making a dual that has seperate ports and chambers? And are the recommended demensions for boxes on JL's site good sounding? |
New member Username: AdasBradenton, Florida Post Number: 8 Registered: Dec-05 | Bump...If someone helps they get a fake cookie |
