New member Username: AudiobahnLyndonville, Vermont United States Post Number: 2 Registered: Dec-05 | i was wondering if you could hook to subs up to a one channel amp |
Silver Member Username: CadillacdbHouston , TX Post Number: 338 Registered: Aug-05 | yes, its easy |
Silver Member Username: TjmutlowPost Number: 505 Registered: Sep-05 | its easy, depending on amp ohm load rating and sub voice coils |
Silver Member Username: CadillacdbHouston , TX Post Number: 339 Registered: Aug-05 | you have two audiobahn aw1206t subs they are 4 ohms dvc so if u wanted to hook them to a mono amp u could wire them together to get either a 4 ohm load or a 1 ohm load Woofer wiring Wizard below http://www.rockfordfosgate.com/rftech/wiringwizard.asp?WoofQty=2+woofers&WoofImp =Dual+Voice+Coil+-+4+ohms+x+2&image.x=14&image.y=13 |
Bronze Member Username: N2audioLawrence, Ks USA Post Number: 48 Registered: Mar-04 | theoretically you can connect any number of speakers to to a 1 ch amp (or any type of amp for that matter) as long as your wiring configuration produces a load the amp can handle. |
