I just loaded the 140 bin on my pansat 2700a, and i get 8.6 but i get a bad channel and scrambled message for echo 7...anyone got any idea what could be going on?
I upgraded to the 140 bin from the 123 bin.
I'd greatly appreciate any help anyone can offer!
Kanobi
Ok, i think i figured out the problem, they say i need to make a dummy sat, does this sound right?
And if so, by using channel master and a channel list, what do i end up doing putting the one sat above the 119 and 110, or should i just put as many as possible
Cliffy21
yeah, just put one dummy sat at the top of the list, and your other 2 will be fine. New bin doesn't understand the first sat in the list only. Hope this helps.
Kanobi
thanks everything is working perfectly fine now, thanks
nope...throw the fcuking piece of shiite in the garbabe and don't ever buy a Pansat again..they are nothing but fcuking trouble and the guide on them sucks...get a viewsat and be happy, I hope BL gets a fcuking virus that makes his eyes straighten out...ROTF
