hi, i need to connect computer to modulator to broadcast a local television. I have s-video out on my graphic card, but it doesnt work. The screen is scrolling and isnt fine. Can I solve it with graphic card with composite tv-out? (not reduction) Is there a different kind of information in composice or its the same and I get same result as with s-video to composite reduction? Thank you.
yes. svideo is analog whereas composite video is not. Get an Nvidia card they are the best for this type of application. The big difference is the fact that a composite video cable can carry a digital signal. which means you can get a higher resolution out of it and it will be a cleaner display.
