Can I install any speaker in front doors? mazda 323 (protegé)?
Username: Panamanian
Panama cityPanama
Post Number: 122
I know (or think) most common speaker on front doors is 6.5, but someone told me ( i dont know if he is lying).
I can see this speaker 5.25", gives a deep bass.
2076_4077_64850161%2C00.html,http://www.pioneerelectronics.com/pna/product/detai l/0,,2076_4077_64850161,00.html
Can I adapt in a 6.5 a smaller speaker and make it work properly? or in a smaller hole install a bigger one?
Is it mucho problem?
thanks
Username: Theelfkeeper
Stockbridge, GA USA
Post Number: 732
you can do just about anything if you have the skills or money to do so. you can fit a 5.25 inch speaker in a 6.5 inch hole with an adapter place easliy. but a 6.5 inch speaker in a 5.25 inch hole will require some cutting. you also have to consider mounting depth. neither size will "give deep bass" though, thats what subs are for, a speaker that small its just not gonna happen.
