Someone help! I recently purchased a 47" projection, Samsung hdtv. When hooked up to the HD box from my cable company, the picture is perfect. However when I go to watch a DVD, I get "ghosting" images going from right to left. I changed out the cables on it, but it didn't seem to make a difference. Can someone tell me what's wrong? I would guess if it were something wrong with the set I'd get the same ghosting while watching tv. HELP!!!
If you connected your DVD via a digital connection, check the setup of your DVD to make sure it is set to digital streaming. Also check the progressive scan.
Blake, You need to give more information on how you have things hooked up. Otherwise we are guessing. Component video? S-video Through a receiver? Are you swapping cables or using multiple inputs on your Samsung?
