12 Inch RE SE vs 15 Inch RE SE
James Palanza
Seeing how the price for them both during the sale is pretty close, my question is, which do you think would be best if ur getting one? The 15's spec's seem to be signifigantly higher than the 12's, specifically in SPL.
Any opinions on either one/both?
Username: Southernrebel
Monroe, Louisiana USA
Post Number: 1804
if space allows...i would go w/ the 15"
more displacement = louder.
Username: Symplestiles
Stockton, CA Usa
Post Number: 332
would 600watts be sufficiant for the 15" SE? or would it sound better going into the 12" SE? If I got the 15" id prolly go sealed w/ a JBL600.1 .. but would that be underpowering it too much?
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 2953
the se is only rated at 600 rms so that would work perfect
Stockton, CA Usa
Post Number: 335
both the 12" and 15" are rated at 600wattS?
Stockton, CA Usa
Post Number: 337
both the 12" and the 15" are rated at 600watts Chauncey? so i could use either and it would work fine with my amp?
Username: Alex_f
Lawrenceburg, Ky Us
Post Number: 146
yes, both r 600 watts
Stockton, CA Usa
Post Number: 338
sweeeeet. gonna order me a 15" SE for sure then. in the back of my 90' Ranger xlt there are 2 fold out seats, one on each side of the cab. im thinkin of turning them into a place for my amp. one for my subs, then later when i buy components and an amp to push them. it would be clean to have the amp fold away into the compartment if i could mount it right. anyone ever seen or done anything similar to this? i wonder how hard it would be with the wires and everything to have it mounted there.. hmmmm
