New member Username: Pimptb89Post Number: 2 Registered: Nov-05 | I have three infinity 4 ohm dvc and i was wondering what the best way to hook them up in a three sub enclosure. Should i wire them parallel or in series and how would i do so? |
Silver Member Username: Alex_fLawrenceburg, Ky Us Post Number: 142 Registered: Nov-05 | first, u half to know the ohm load on the amp. what is it? |
Silver Member Username: TjmutlowPost Number: 299 Registered: Sep-05 | you will get either 2.66 ohm or 6ohm accoring to 12volt.com |
Gold Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 2979 Registered: Jul-05 | an amp that is at least 2 ohm stable |
Silver Member Username: Alex_fLawrenceburg, Ky Us Post Number: 143 Registered: Nov-05 | this should help u http://www.crutchfieldadvisor.com/learningcenter/car/subwoofers_wiring.html?subs =3&impedance=DVC4x2 whats up chauncey? |
Gold Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 2980 Registered: Jul-05 | sup |
Silver Member Username: Alex_fLawrenceburg, Ky Us Post Number: 144 Registered: Nov-05 | not much here, u want to get on aim?got to tell u something |
