any one can help with Viewsat keys. I put the new keys under 00 and 01 for niaga but now the receiver says NO Channel
Iceman182
Put them under 88 and 89, then you'll be aight.....
Daaku Mandar_Singh
get the latest SuperBin for your viewsat which will save you the hassle of changing keys ever buddy. Don't bother about changing keys now since there is a new bin with Autoroll in it. Go and get it from www.dsscentral .net, it is in the file section there. just reflash your receiver with that bin and enter the keys manually only once on your receiver and you will not need to change keys ever there as the latest bin will do it for you always.
