Paint
Username: Dropthatbass
Minnesota US
Post Number: 82
about how much will it cost to paint my 1994 buick century?
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 2916
depends on what u want
Username: Lexuscoop
Post Number: 207
think around 5k
Minnesota US
Post Number: 83
just like a plain black
Post Number: 2917
u can get a custom for 1000 and up, u can go to macco for around 500 or little less, depends on where u live and how much they charge
Post Number: 2918
what color is it now, i have heard of places not charging as much if it was already or around the same color as what u are getting it painted
Username: Nutty91rs
Bloomington, Indiana USA
Post Number: 316
Cheapest a decent job should cost is around 1500, Maco will spray paint on your car for $500, but they won't sand and prep it you'll have to do that yourself. If you can do the body work, sand, prime, and prep the car then you could trailor it to a place like Maco and get it sprayed, otherwise just take it to a body shop and have them do there thing.
