Do I need a better fuse?
Username: Scocho
New Hampshire
I'm going to get my amp and sub installed, and I'm wondering about the install kit, and the fuse in particular. The amp is an Elevation Audio XS125.4:
http://www.elevationaudio.com/xs1254.htm
For the wiring kit, I was thinking I'd get this 4 gauge 4 channel kit from KnuKonceptz:
http://www.knukonceptz.com/productDetail.cfm?prodID=KOL-AK44
This kit comes with a fuse holder that can handle up to 80A. I was wondering I needed higher, like 100A (someone told me I needed to). Thank you, I'm new to all this, so I'm sorry if this is a silly question.
Username: Geekbike
Post Number: 396
Your fuse should match the amperage rating of the wire or even a bit lower, just to be safe. 4 gauge should have at max, a 150amp fuse.
http://www.the12volt.com/info/recwirsz.asp
Username: Scocho
New Hampshire
Okay, thanks.
